problem with adding music DVDs
ougee
Post by ougee »
First of all, great program, thanks!
But I have a problem with adding music DVDs. I tried many different scripts but none of it finds my DVDs. Though I know that the DVDs are on sale on those website.
For example, I'd like to add Bee Gees "Live by request" DVD. I select the Amazon.com script and it nothing is found.
Any suggestion pls?
Thanks.
About these scripts, maybe some filter to include only movies? (but I doubt it)
Or maybe these script do not work anymore? Do they work for other movies?
I cannot help you much, as most of the scripts were made by users, and I do not have time to work on these scripts :/
ougee
Post by ougee »
It works fine with movies DVD. I use IMDB and Amazon scripts. All movies are found and added without any problem.
As for the music DVD I also thought that it might be a problem with "movies only" filter in the Amazon script. But on the Amazon there's only one category DVD which doesn't make difference between music and movie DVDs.
So I'm little bit stuck here :(
Little bit confused which script exactly you are talking about .. Amazon ? IMDB with optional Amazon picture ? Please give name and version number from the scripts listing (version number is found down on the left corner).
As far as I know the Amazon.com script does not work at the moment and has to be fixed: viewtopic.php?t=3692
But it shouldn't work for all dvd: movie and music. So maybe this is your problem.
If you are talking about the IMDB script, Bee Gees "Live by request" is not a good example, as it is not found on imdb.com. So it should be obvious, that the script cannot find it, too.
