Green cross in front of each title
edjenjudi
Post by edjenjudi »
Hi.I have just found this program and i think it is what i have been looking for. I found it easy to set up and use.Unfortunately while refining it to how i wanted to us it i have done something that as yet i have not been able to undo.In the main title column in front of each movie name there has appeared a green cross which i now have to click on to open before i can high lite a movie name to see all it's detail. If someone on this forum has made the same mistake that i have could you kindly let me know how to remove all these green crosses. Any suggestions would be very helpful to this computer dunce.
Thank you. edjenjudi
I think that you used the "group by" function. This makes groups (with a green +) on the selected field. So by going in Tools -> Group by, you can disable this or select which field to use for the groups.
