Auto-Open File at Start-Up
res0zvle
Post by res0zvle »
Great program. The only problem I'm having is the auto-open feature at start-up. The program is opening the same file at start-up despite my clicking the preferences settings for another file to open at start-up. Any ideas?
Jim
Check that you did not modify the shortcut icon to specify a file to open.
Else, does it remember the good file to open in the preferences despites it opens the wrong one? Or does the file name field revert to the old value ?
res0zvle
Post by res0zvle »
Thanks very much, that was the problem. I copied the file from the main directory but for some reason it linked the file from an entirely different directory. Thanks, and again, great program!
uote="antp"]Check that you did not modify the shortcut icon to specify a file to open.
Else, does it remember the good file to open in the preferences despites it opens the wrong one? Or does the file name field revert to the old value ?[/quote]
