Problem with the label (Vista)
dku
Post by dku »
Hello,
I'm using Vista 64 (I know this is not a good idea so far ...), but the labels of edit fields are disappearing ... Any idea or workaround ? (I can work, but is not so convenient).
By the way, gives it a solution to mark the movies as seen ?
Thanks for any hints
Bye
Didier
Re: Problem with the label (Vista)
Please read this topic about your problem on Vista: viewtopic.php?t=3468
You can use any field you don't need for other purpose. If you then want to sort your list for "seen/unseen" use the "group" function (from the tools menu or rightclick the list). You can change the name of the field in your translation file if you like. Or i.e. use the checkbox on the list to mark seen films..
You can also use the checkboxes at the front of the title in the main list
