double-sided report problem
Atom
Post by Atom »
Hi all!
Being my first post here, first off all I would like to thank antp very much for this great program. I have been using it for a couples of years now and I really love it :clapping: :clapping: :grinking: :grinking: . ¡Thank you!
The thing is that, now, in order to do a two sided report.what I have done is a report with two pages, each page with a "master data" "band" filling the whole page. The thing is that the information appears ok, *but* what I get is first all the "front" pages for all the films and, after them, all the "back" pages for all the films.
Of course what I would like to have is for each film the two corresponding pages one after the other so that I can print the full report double-sided. I have looked at the manual and searched the forums but haven't found anything regarding this subject, so, is it possible?
This kind of things can sometimes be done in the printer settings. If your printer does not offer it, you can print to a PDF (using CutePDF or PDFCreator for example) and then in Adobe Acrobat Reader you have the option to print odd or even pages.
Atom
Post by Atom »
Hi antp, thanks for the quick answer.
Yes, what I do in fact is printing it to a pdf so that I can move the report around to print it. But, the problem is the other way round: I do have a double side printer, *but* the order the report generates is not the "correct" one.
If I call "f" for front and "b" for back, and the number is the film number, I want the report to generate 1f 1b 2f 2b 3f 3b ...nf nb (i.e., film1-front, film1-back, film2-front, film2-back ...), so that I can pdf it and double-side print it easily.
But what I get form AMC is 1f 2f 3f...nf 1b 2b...nb i.e., *all* the frot pages first, followed by *all* the back faces. You see what I mean? Is this the expected behaviour?
ps: BTW you have to know that I can use AMC with no problems also in Linux under wine. You have some minor glitches in the designer but it works 99%. Great! :-)
I see, I made few tests but it seems that it is not possible to make it otherwise :/
The report part is not made by me, I use a ready-to-use component that handles the preview and print. The designer is also part of that.
Atom
Post by Atom »
Ok, thanks for the help. I finally did a python script which reorders the pdf.
