How to move files after renaming?
torrent_socialist
Post by torrent_socialist »
Hello! I was unable to find this discussed in other threads or in the help documentation. Does Renamer (2.12) have the ability to move files? I have figured out how to rename files to match the parent folder. After renaming, I would like to move the files up two folders (or at least one). Is this possible? If so, I'd appreciate some guidance.
Re: How to move files after renaming?
Yes, when renaming it actually used the "MoveFile" function from Windows so you can make the file go in another folder easily.
For example if you insert ..\..\ in front of the file name, the file will be moved two folders up.
Sorry for the delay in answer ;)
