massupdate from imdb site?? is it possible
scar0x
Post by scar0x »
hi
i was just wondering if it is possible to get information from IMDB or other scripts, for more then one movies at the same time.
i mean you could select all your movies and then hit update or something then the software updates them all.
thx
scar
Select several movies, then Tools -> Scripting, then something like "IMDB Batch"
scar0x
Post by scar0x »
yes thx i just read the thread.
however it doenst seem to import any covers :(
i am using the latest verson of ant
Yes I probably forgot to update it when I updated the other IMDB scripts... I'll correct that when I'll have time.
It should be not too difficult to do, you can try to do it by comparing the script part that is near the "// picture" line.
scar0x
Post by scar0x »
ok i tried to change the batch file as hard as i could. but with no results. I am not really good with scripting. So can anyone help me with some changes to the batch IMDB script i cannot seem to be able to download the BIG pictures. :(
thx in advance
