Update HoyCinema(ES)v1.0 to v1.1
legrad
Post by legrad »
Authors=Legrad
Title=HoyCinema(ES)
Description=
Site=www.hoyCinema.com
Language=ES
Version=1.1
Requires=3.5.0
Comments=
License=
 program HoyCinema;
  MovieURL: string;
   n,len, tag: Integer;
   c: char;
   t: String;
   tag := 0;
   t := '';
   len := length(s);
   for n :=1 to len do
     c := Copy(s,n,1);
     if c = '''' then
        c := ' ';
        t := t + c;
   s := t;
   result := t;
  Result := -1;
  if StartAt < 0 then
    StartAt := 0;
      Result := i;
  InitialPos: Integer;
  if InitialPos = 0 then
    result := ''
    InitialPos := Pos(EndTag, S);
      result := S
      Delete(S, 1, InitialPos + 1);
   c: char;
   t: String;
   tag := 0;
   t := '';
   len := length(s);
   for n :=1 to len do
      c := Copy(s,n,1);
      if c = #9 then
         c := ' ';
      if(tag=1) then
         if(c='>') then tag := 0;
         continue;
         if(c='<') then
            tag := 1;
            continue;
         t := t + c;
   s := t;
   result := t;
function UpFirstLetterWord(texto:string):string;
var espaco:integer;
sst:string;
texto:=AnsiUpFirstLetter(AnsiLowerCase(texto));
    espaco:=Pos(' ',texto);
    sst:=AnsiUpperCase(Copy(texto,espaco+1,1));
texto:=Copy(texto,1,espaco-1)+'/|\'+sst+Copy(texto,espaco+2,length(texto));
until Pos(' ',texto)=0;
texto := StringReplace(texto, '/|\', ' ');
if Copy(texto,1,1)=' ' then
  texto:=Copy(texto,2,length(texto));
result:=texto;
  BeginPos, EndPos: Integer;
  BeginPoss, EndPoss: Integer;
  strPage := GetPage(Address);
  BeginPos := Pos('en el dominio <b>www.hoycinema.com<', strPage);
  if(BeginPos > -1)then
      Delete(strPage, 1, BeginPos);
      BeginPos := Pos('href="http://www.hoycinema.com/sinopsis/', strPage);
      EndPos := 1;
          MovieId := Copy(strPage,+40, EndPos-40);
          MovieAddr := 'http://www.hoycinema.com/sinopsis/' + MovieId;
          BeginPoss := Pos(')"',strPage);
          EndPoss := Pos(' -', strPage);
          MovieTitle  := TextBetween(MovieTitle , '>', '-');
          MovieTitle  := StringReplace(MovieTitle , 'á', 'á');
          MovieTitle  := StringReplace(MovieTitle , 'é', 'é');
          MovieTitle  := StringReplace(MovieTitle , 'í', 'í');
          MovieTitle  := StringReplace(MovieTitle , 'ó', 'ó');
          MovieTitle  := StringReplace(MovieTitle , 'ú', 'ú');
          MovieTitle  := StringReplace(MovieTitle , 'Â', '');
          MovieTitle  := StringReplace(MovieTitle , 'ñ', 'ñ');
          DeleteTags(MovieTitle);
           BeginPos := -1;
           PickTreeSort;
    PickTreeExec(Address);
    AnalyzeMoviePage(Address);
    AnalyzeVideoPage(Address);
  Item: string;
  Comments: string;
  Actors: string;
  Directors: string;
  Description: string;
  Busca: integer;
   //URL
  // sinopsis
 LineNr := FindLine('<span id="esp_sup__ctl0_sinopsis_lbl">', Page, 0);
  if LineNr > 0 then
    Item := copy(Page.Text, pos('<span id="esp_sup__ctl0_sinopsis_lbl">',Page.Text), length(Page.Text));
    Item := TextBetween (Item, '<span id="esp_sup__ctl0_sinopsis_lbl">', '</td>');
    Item := StringReplace(Item , #13#10, '');
    DeleteTags (Item);
    Item  := Trim(Item );
    HTMLDecode(Item);
procedure AnalyzeVideoPage(Address: string);
  Item: string;
  Comments: string;
  Actors: string;
  Directors: string;
  Busca: integer;
  Description := '';
  // URL
  Address := StringReplace (Address,'sinopsis/','');
  // Titulo traducido
  LineNr := FindLine('<TITLE>', Page, 0);
  Item := TextBetween (Line, '<TITLE>', '-');
  Item  := UpFirstLetterWord(Item);
  HTMLDecode(Item);
  // año
  LineNr := FindLine('<strong>· Año:', Page, 0);
  if LineNr > 0 then
    Item := copy(Page.Text, pos('<strong>· Año:',Page.Text), length(Page.Text));
    Item := TextBetween (Item, '"contenido_txt">', '</a>');
    DeleteTags (Item);
    Item   := AnsiUpFirstLetter(Item );
    HTMLDecode(Item);
  // Categoria
  LineNr := FindLine('<strong>· Género: ', Page, 0);
  if LineNr > 0 then
    Item := copy(Page.Text, pos('<strong>· Género: ',Page.Text), length(Page.Text));
    Item  := StringReplace(Item , '   ', '');
    DeleteTags (Item);
    HTMLDecode(Item);
   // pais
  LineNr := FindLine('<strong>· País:', Page, 0);
  if LineNr > 0 then
    Item := copy(Page.Text, pos('<strong>· País:',Page.Text), length(Page.Text));
    Item := TextBetween (Item, 'ctl0_pais_lbl">', '</span>');
    DeleteTags (Item);
    HTMLDecode(Item);
   // director
  LineNr := FindLine('<strong>· Director:', Page, 0);
  if LineNr > 0 then
    Item := copy(Page.Text, pos('<strong>· Director:',Page.Text), length(Page.Text));
    DeleteTags (Item);
    HTMLDecode(Item);
  // reparto
  LineNr := FindLine('Ficha artística</td>', Page, 0);
  if LineNr > 0 then
    Item := copy(Page.Text, pos('Ficha artística</td>',Page.Text), length(Page.Text));
    Item := TextBetween (Item, 'htm">·', '</table>');
    Item := StringReplace(Item ,'      ', '');
    Item := StringReplace(Item ,'·', ', ');
    DeleteTags (Item);
    HTMLDecode(Item);
    Item  := StringReplace(Item , '      ,', ',');
 // guion
 LineNr := FindLine('<span id="tdsupizq__ctl0_guion_lbl"><a', Page, 0);
  if LineNr > 0 then
    Item := copy(Page.Text, pos('<span id="tdsupizq__ctl0_guion_lbl"><a',Page.Text), length(Page.Text));
    Item := TextBetween (Item, 'class="contenido_txt" >', '</span></td>');
    Item := StringReplace(Item ,'</a>', ', ');
    DeleteTags (Item);
    HTMLDecode(Item);
    SetField(fieldComments, Trim ('Guión: '+Item));
  // Caratula
  LineNr := FindLine('src="http://media.hoycinema.com/pic.aspx?img=', Page, 0);
  if LineNr <> -1 then
     Item := TextBetween (Line, 'src="', '.jpg');
     GetPicture (Item+'.jpg');
Input('HoyCinema', 'Buscar:', MovieName);
     if(GetOption('Sin resultado') = 0) then  Input('HoyCinema', 'Buscar:', MovieName);
   AnalyzePage('http://www.google.es/search?num=100&hl=es&as_qdr=all&q=' + UrlEncode(MovieName)+'+site%3Awww.hoycinema.com&btnG=B%C3%BAsqueda&meta=');
