Update decine21(ES)v1.0 to v1.1
legrad
Post by legrad »
Authors=Legrad
Title=Decine21(ES)
Description=
Site=www.decine21.com
Language=ES
Version=1.1
Requires=3.5.0
Comments=
License=
program Decine21;
 Uses StringUtils7552;
  BaseURL1 = 'http://www.decine21.com/EstructurasBd/Peliculas\';
  MovieURL: string;
function UpFirstLetterWord(texto:string):string;
var espaco:integer;
sst:string;
texto:=AnsiUpFirstLetter(AnsiLowerCase(texto));
    espaco:=Pos(' ',texto);
    sst:=AnsiUpperCase(Copy(texto,espaco+1,1));
texto:=Copy(texto,1,espaco-1)+'/|\'+sst+Copy(texto,espaco+2,length(texto));
until Pos(' ',texto)=0;
texto := StringReplace(texto, '/|\', ' ');
if Copy(texto,1,1)=' ' then
  texto:=Copy(texto,2,length(texto));
result:=texto;
   n,len, tag: Integer;
   c: char;
   t: String;
   tag := 0;
   t := '';
   len := length(s);
   for n :=1 to len do
     c := Copy(s,n,1);
     // quitamos las comillas
     if c = '''' then
        c := ' ';
        t := t + c;
   s := t;
   result := t;
   c: char;
   t: String;
   tag := 0;
   t := '';
   len := length(s);
   for n :=1 to len do
      c := Copy(s,n,1);
      // quitamos los tabuladores
      if c = #9 then
         c := ' ';
      if(tag=1) then
         if(c='>') then tag := 0;
         continue;
         if(c='<') then
            tag := 1;
            continue;
         t := t + c;
   s := t;
   result := t;
  strPage, strPages, MovieAddr, MovieTitle, MovieDate, MovieID: string;
  BeginPos, EndPos, BeginPo, EndPo: Integer;
  strPage := GetPage(Address);
  BeginPos := Pos(' en el dominio <b>www.decine21.com', strPage);
  if(BeginPos > -1)then
      //PickTreeAdd('Resultados para: ' + MovieName, '');
      Delete(strPage, 1, BeginPos);
      BeginPos := Pos('href="http://www.decine21.com/FrmPeliculas.asp?id=', strPage);
      EndPos := 1;
        //Delete(strPage =elimina beginpos superior y deja el resto direccion
          //MovieId direccion completa de carga datos
          MovieId := Copy(strPage, +50, EndPos-50);
          MovieAddr := 'http://www.decine21.com/FrmPeliculas.asp?id=' + MovieId;
          BeginPos := Pos('clk(this',strPage);
          EndPos := Pos('</a>', strPage);
          MovieTitle := Copy(strPage,BeginPos+20, EndPos-8);
          MovieTitle  := TextBetween (MovieTitle , 'l>', '-');
          MovieTitle  := UpFirstLetterWord(MovieTitle );
          MovieTitle  := StringReplace(MovieTitle , 'ã‘', 'ñ');
          MovieTitle  := StringReplace(MovieTitle , '·', '');
          MovieTitle  := StringReplace(MovieTitle , 'ã￾', 'á');
          MovieTitle  := StringReplace(MovieTitle , 'ã©', 'é');
          MovieTitle  := StringReplace(MovieTitle , 'ã￾', 'í');
          MovieTitle  := StringReplace(MovieTitle , 'ã“', 'ó');
          MovieTitle  := StringReplace(MovieTitle , 'ã³', 'ó');
          MovieTitle  := StringReplace(MovieTitle , 'ãš', 'ú');
          MovieTitle  := StringReplace(MovieTitle , 'ãº', 'ú');
          MovieTitle  := StringReplace(MovieTitle , 'ã¡', 'á');
          MovieTitle  := StringReplace(MovieTitle , 'ã­', 'í');
          MovieTitle  := StringReplace(MovieTitle , 'ã±', 'ú');
           MovieTitle  := StringReplace(MovieTitle , 'á', 'á');
           MovieTitle := StringReplace(MovieTitle , 'é', 'é');
           MovieTitle  := StringReplace(MovieTitle , 'í', 'í');
           MovieTitle  := StringReplace(MovieTitle , 'ó', 'ó');
           MovieTitle  := StringReplace(MovieTitle , 'ú', 'ú');
           MovieTitle  := StringReplace(MovieTitle , 'ã±', 'ñ');
           MovieTitle  := StringReplace(MovieTitle , 'ñ', 'ñ');
           MovieTitle  := StringReplace(MovieTitle , 'Â', '');
          DeleteTags(MovieTitle);
          PickTreeAdd(MovieTitle,  MovieAddr);
           BeginPos := -1;
           PickTreeSort;
    PickTreeExec(Address)
    AnalyzeMoviePage(Address);
  Item: string;
  Comments: string;
  Actors: string;
  Directors: string;
  Description: string;
  BaseURL2: string;
  Beginpos: string;
  titre_film: string;
  EndPos: string;
  Item1: string;
  Item2: string;
   Movie: string;
  Description := '';
 // URL
   //Titulo Original
 LineNr := FindLine('columnadatos', Page, 0);
  if LineNr <> -1 then
    Item := copy(Page.Text, pos('columnadatos',Page.Text), length(Page.Text));
    Item := TextBetween (Item, 'titulooriginal', '</font><br><br><div');
     Item:= BorraComillas(Item);
     Item  := StringReplace(Item , '>', ' ');
    Item := StringReplace(Item , #13#10, ' ');
    Item  := StringReplace(Item , '   ', ' ');
    Item  := Trim(Item );
    DeleteTags(Item)
    HTMLDecode(Item);
  //Titulo Traducido
    Item := copy(Page.Text, pos('<title>',Page.Text), length(Page.Text));
    Item := TextBetween (Item, '<title>', '-');
    DeleteTags(Item)
    HTMLDecode(Item);
    SetField(fieldTranslatedTitle, trim (Item));
  // Director
  LineNr := FindLine('Direcci', Page, 0);
    Item := copy(Page.Text, pos('Dirección:',Page.Text), length(Page.Text));
    Item := TextBetween (Item, 'Dirección:', '</a>');
    DeleteTags(Item)
    HTMLDecode(Item);
    SetField(fieldDirector, trim (Item));
   // Año
  LineNr := FindLine('Año de producci', Page, 0);
    Item := copy(Page.Text, pos('Año de producci',Page.Text), length(Page.Text));
    Item := TextBetween (Item, '>', '<');
    DeleteTags(Item)
    HTMLDecode(Item);
    SetField(fieldYear, trim (Item));
   // Actores
  LineNr := FindLine('<br>Intérpretes: ', Page, 0);
    Item := copy(Page.Text, pos('<br>Intérpretes: ',Page.Text), length(Page.Text));
    Item := TextBetween (Item, '<br>Intérpretes: ', '</font><br>Guión');
    DeleteTags(Item)
    HTMLDecode(Item);
    SetField(fieldActors, trim (Item));
  //Categoria
  LineNr := FindLine('Género: ', Page, 0);
    Item := copy(Page.Text, pos('Género: ',Page.Text), length(Page.Text));
    Item := TextBetween (Item, '>', '</font><br>');
  Item := StringReplace(Item , #13#10, '');
    Item  := StringReplace(Item , '   ', '');
    DeleteTags(Item);
  HTMLDecode(Item);
  //Duracion
  LineNr := FindLine('Duración: ', Page, 0);
    Item := copy(Page.Text, pos('Duración: ',Page.Text), length(Page.Text));
    Item := TextBetween (Item, '>', 'min');
    DeleteTags(Item);
    HTMLDecode(Item);
   //sinopsis
  LineNr := FindLine('columnacomentario', Page, 0);
    Item := copy(Page.Text, pos('columnacomentario',Page.Text), length(Page.Text));
    Item := TextBetween (Item, 'columnacomentario', '</div></td></tr><tr><td class=');
    Item  := StringReplace(Item , 'height= 10 >', '');
    DeleteTags(Item);
  HTMLDecode(Item);
    SetField(fieldDescription, trim (Item));
     // Comentarios
  LineNr := FindLine('</font><br>Guión: ', Page, 0);
    Item := copy(Page.Text, pos('</font><br>Guión: ',Page.Text), length(Page.Text));
    Item := TextBetween (Item, '</font><br>Guión: ', '<br>Distribuye');
    Item  := StringReplace(Item , ' ', #13#10);
    Item  := StringReplace(Item , '</a></font>', #13#10);
    Item  := StringReplace(Item , '</a></font><br>', '/');
    DeleteTags(Item);
    HTMLDecode(Item);
    SetField(fieldComments, trim ('Guión: '+Item));
   // Productor
  LineNr := FindLine('Produce:', Page, 0);
    Item := copy(Page.Text, pos('Produce:',Page.Text), length(Page.Text));
    Item := TextBetween (Item, 'Produce:', '</span>');
    DeleteTags(Item)
    HTMLDecode(Item);
    SetField(fieldProducer, trim (Item));
  // Picture
  LineNr := FindLine('Imagenes\Peliculas\Criticas', Page, 0);
    Item := copy(Page.Text, pos('Imagenes\Peliculas\Criticas',Page.Text), length(Page.Text));
    Item := TextBetween (Item, 'http://www.decine21.com/EstructurasBd/Peliculas\', 'style=');
    DeleteTags(Item)
    HTMLDecode(Item);
   GetPicture ('http://www.decine21.com/EstructurasBd/Peliculas\'+Item);
            Input('Decine21', 'Buscar', MovieName);
     if(GetOption('') = 0) then  Input('Decine21', 'Buscar', MovieName);
   AnalyzePage('http://www.google.es/search?num=100&hl=es&as_qdr=all&q=' + UrlEncode(MovieName)+'+site%3Awww.decine21.com&btnG=B%C3%BAsqueda&meta=');
