nuevo script Comohacercine(ES)v1.0
legrad
Post by legrad »
Authors=Legrad
Title=Comohacercine(ES)
Description=
Site=www.Comohacercine.com
Language=ES
Version=1.0
Requires=3.5.0
Comments=
License=
program Comohacercine;
  MovieURL: string;
function Acentos(Acento: string) :string;
          Acento := StringReplace(Acento, 'Ã-' , 'á');
          //Acento := StringReplace(Acento, 'Ã' ,  'á');
          Acento := StringReplace(Acento, 'ã¡' , 'á');
          Acento := StringReplace(Acento, 'iã³', 'á');
          Acento := StringReplace(Acento, 'Ã￾' , 'á');
          Acento := StringReplace(Acento, 'ã',   'á');
          Acento := StringReplace(Acento, 'é',  'é');
          Acento := StringReplace(Acento, 'ã©' , 'é');
          Acento := StringReplace(Acento, 'ãª',  'é');
          Acento := StringReplace(Acento, 'í',  'í');
          Acento := StringReplace(Acento, 'ã­',  'í');
          Acento := StringReplace(Acento, 'ó',  'ó');
          Acento := StringReplace(Acento, 'ã³',  'ó');
          Acento := StringReplace(Acento, 'á³',  'ó');
          Acento := StringReplace(Acento, 'ú',  'ù');
          Acento := StringReplace(Acento, 'ñ',  'ñ');
          Acento := StringReplace(Acento, 'ã±',  'ñ');
          Acento := StringReplace(Acento, 'º',  'º');
          Acento := StringReplace(Acento, '&#',   '');
          Acento := StringReplace(Acento, '39;',  '');
          Acento := StringReplace(Acento, 'Â',    '');
result := Acento;
   n,len, tag: Integer;
   c: char;
   t: String;
   tag := 0;
   t := '';
   len := length(s);
   for n :=1 to len do
     c := Copy(s,n,1);
     if c = '''' then
        c := ' ';
        t := t + c;
   s := t;
   result := t;
  Result := -1;
  if StartAt < 0 then
    StartAt := 0;
      Result := i;
  InitialPos: Integer;
  if InitialPos = 0 then
    result := ''
    InitialPos := Pos(EndTag, S);
      result := S
      Delete(S, 1, InitialPos + 1);
   c: char;
   t: String;
   tag := 0;
   t := '';
   len := length(s);
   for n :=1 to len do
      c := Copy(s,n,1);
      if c = #9 then
         c := ' ';
      if(tag=1) then
         if(c='>') then tag := 0;
         continue;
         if(c='<') then
            tag := 1;
            continue;
         t := t + c;
   s := t;
   result := t;
  BeginPos, EndPos: Integer;
  BeginPoss, EndPoss: Integer;
  strPage := GetPage(Address);
  BeginPos := Pos('</b> en el dominio <b>www.comohacercine.com</b>', strPage);
  if(BeginPos > -1)then
      Delete(strPage, 1, BeginPos);
      BeginPos := Pos('http://www.comohacercine.com/cine_ficha.php?id=', strPage);
      EndPos := 1;
          MovieId := Copy(strPage,+47, EndPos-47);
          MovieAddr := 'http://www.comohacercine.com/cine_ficha.php?id=' + MovieId;
          BeginPoss := Pos(')"',strPage);
          EndPoss := Pos('</a>', strPage);
          MovieTitle  := TextBetween(MovieTitle ,'>', '-');
          MovieTitle  :=Acentos(MovieTitle);
          DeleteTags(MovieTitle);
           BeginPos := -1;
    PickTreeExec(Address)
    AnalyzeMoviePage(Address);
  Item: string;
  Comments: string;
  Actors: string;
  Directors: string;
  Description: string;
  Busca: integer;
  Description := '';
  Comments := '';
  // URL
  // Titulo traducido
  Item := TextBetween (Line, '<title>', '-');
  HTMLDecode(Item);
  // Titulo original
  LineNr := FindLine('<span class="link-articulos2">', Page, 0);
  if LineNr > 0 then
    Item := copy(Page.Text, pos('<span class="link-articulos2">',Page.Text), length(Page.Text));
    Item := TextBetween (Item, '<br><i>', '</i> ');
  HTMLDecode(Item);
     // sinopsis
 LineNr := FindLine('<span class="link-articulos2', Page, 0);
  if LineNr > 0 then
    Item := copy(Page.Text, pos('<span class="link-articulos2',Page.Text), length(Page.Text));
    Item := TextBetween (Item, 'class="v10">', '</td>');
    Item := StringReplace (Item, #13#10, '');
    DeleteTags (Item);
    Item  := Trim(Item );
    HTMLDecode(Item);
  // año
LineNr := FindLine('FICHA TÉCNICA</span>', Page, 0);
  if LineNr > 0 then
    Item := copy(Page.Text, pos('FICHA TÉCNICA</span>',Page.Text), length(Page.Text));
    Item := TextBetween (Item, 'FICHA TÉCNICA</span>', ', ');
    Item  := StringReplace(Item ,#13#10, '');
    DeleteTags(Item);
    HTMLDecode(Item);
    HTMLDecode(Item);
  // pais
  if LineNr > 0 then
    Item := copy(Page.Text, pos('class="v10">',Page.Text), length(Page.Text));
    Item := TextBetween (Item, ', ', '<BR><b>');
    HTMLDecode(Item);
    Item  := StringReplace(Item , 'EE.UU.', 'USA');
    // director
  LineNr := FindLine('<b>Director:</b> <font class=colorcitodenuri>', Page, 0);
  if LineNr > 0 then
    Item := copy(Page.Text, pos('<b>Director:</b> <font class=colorcitodenuri>',Page.Text), length(Page.Text));
    Item := TextBetween (Item, '<b>Director:</b> <font class=colorcitodenuri>', '</font><BR>');
    HTMLDecode(Item);
  // Duracion
  LineNr := FindLine('Duración:</b> <font class=colorcitodenuri>', Page, 0);
  if LineNr > 0 then
    Item := copy(Page.Text, pos('Duración:</b> <font class=colorcitodenuri>',Page.Text), length(Page.Text));
    Item := TextBetween (Item, 'Duración:</b> <font class=colorcitodenuri>', 'minutos');
    HTMLDecode(Item);
  // Reparto
  LineNr := FindLine('Actores principales: </b><font class=colorcitodenuri>', Page, 0);
  if LineNr > 0 then
    Item := copy(Page.Text, pos('Actores principales: </b><font class=colorcitodenuri>',Page.Text), length(Page.Text));
    Item := TextBetween (Item, 'Actores principales: </b><font class=colorcitodenuri>', '</font><BR>');
    DeleteTags (Item);
    HTMLDecode(Item);
  // Productor
  LineNr := FindLine('>Producción:</b>   <font class=colorcitodenuri>', Page, 0);
  if LineNr > 0 then
    Item := copy(Page.Text, pos('>Producción:</b>   <font class=colorcitodenuri>',Page.Text), length(Page.Text));
    Item := TextBetween (Item, '>Producción:</b>   <font class=colorcitodenuri>', '</font><BR>');
    HTMLDecode(Item);
  // Guión
   LineNr := FindLine('Guión:</b>   <font class=colorcitodenuri>', Page, 0);
  if LineNr <> -1 then
    Item := copy(Page.Text, pos('Guión:</b>   <font class=colorcitodenuri>',Page.Text), length(Page.Text));
    Item := TextBetween (Item, 'Guión:</b>   <font class=colorcitodenuri>', '</font><BR>');
    DeleteTags (Item);
    Item  := Trim(Item);
    HTMLDecode(Item);
    Comments := Comments + 'Guión: ' + Item +#13#10;
  // Fotografía
   LineNr := FindLine('Dirección de fotografía:</b>   <font class=colorcitodenuri>', Page, 0);
    Item := copy(Page.Text, pos('Dirección de fotografía:</b>   <font class=colorcitodenuri>',Page.Text), length(Page.Text));
    Item := TextBetween (Item, 'Dirección de fotografía:</b>   <font class=colorcitodenuri>', '</font><BR>');
    DeleteTags (Item);
    Item  := Trim(Item);
    HTMLDecode(Item);
    Comments := Comments + 'Fotografía: ' + Item +#13#10;
  // Vestuario
   LineNr := FindLine('Vestuario:</b>   <font class=colorcitodenuri>', Page, 0);
    Item := copy(Page.Text, pos('Vestuario:</b>   <font class=colorcitodenuri>',Page.Text), length(Page.Text));
    Item := TextBetween (Item, 'Vestuario:</b>   <font class=colorcitodenuri>', '</font><BR>');
    DeleteTags (Item);
    Item  := Trim(Item);
    HTMLDecode(Item);
    Comments := Comments + 'Vestuario: ' + Item +#13#10;
  // Montaje
   LineNr := FindLine('Montaje:</b>   <font class=colorcitodenuri>', Page, 0);
    Item := copy(Page.Text, pos('Montaje:</b>   <font class=colorcitodenuri>',Page.Text), length(Page.Text));
    Item := TextBetween (Item, 'Montaje:</b>   <font class=colorcitodenuri>', '</font><BR>');
    DeleteTags (Item);
    Item  := Trim(Item);
    HTMLDecode(Item);
    Comments := Comments + 'Montaje: ' + Item +#13#10;
  // Banda Sonora
   LineNr := FindLine('Banda sonora:</b>   <font class=colorcitodenuri>', Page, 0);
    Item := copy(Page.Text, pos('Banda sonora:</b>   <font class=colorcitodenuri>',Page.Text), length(Page.Text));
    Item := TextBetween (Item, 'Banda sonora:</b>   <font class=colorcitodenuri>', '</font><BR>');
    DeleteTags (Item);
    Item  := Trim(Item);
    HTMLDecode(Item);
    Comments := Comments + 'Banda Sonora: ' + Item +#13#10;
     // Ficha Artistica
   LineNr := FindLine('FICHA ARTÍSTICA</span> ', Page, 0);
    Item := copy(Page.Text, pos('FICHA ARTÍSTICA</span> ',Page.Text), length(Page.Text));
    Item := TextBetween (Item, '<font class=colorcitodenuri>', '</font><BR>');
    DeleteTags (Item);
    Item  := Trim(Item);
    HTMLDecode(Item);
    Comments := Comments + 'Ficha Artistica: ' + Item +#13#10;
  // Distribuidora
   LineNr := FindLine('<b>Distribuidora:</b> <font class=colorcitodenuri>', Page, 0);
    Item := copy(Page.Text, pos('<b>Distribuidora:</b> <font class=colorcitodenuri>',Page.Text), length(Page.Text));
    Item := TextBetween (Item, '<b>Distribuidora:</b> <font class=colorcitodenuri>', '</font><BR>');
    DeleteTags (Item);
    Item  := Trim(Item);
    HTMLDecode(Item);
    Comments := Comments + 'Distribuidora: ' + Item +#13#10;
  // Calificación
   LineNr := FindLine('<b>Calificación:</b>  <font class=colorcitodenuri>', Page, 0);
    Item := copy(Page.Text, pos('<b>Calificación:</b>  <font class=colorcitodenuri>',Page.Text), length(Page.Text));
    Item := TextBetween (Item, '<b>Calificación:</b>  <font class=colorcitodenuri>', '</font><BR>');
    DeleteTags (Item);
    Item  := Trim(Item);
    HTMLDecode(Item);
    Comments := Comments + 'Calificación: ' + Item +#13#10;
  // Fecha de estreno
   LineNr := FindLine('Fecha de estreno:</b>  <font class=colorcitodenuri>', Page, 0);
    Item := copy(Page.Text, pos('Fecha de estreno:</b>  <font class=colorcitodenuri>',Page.Text), length(Page.Text));
    Item := TextBetween (Item, 'Fecha de estreno:</b>  <font class=colorcitodenuri>', '</font><BR>');
    DeleteTags (Item);
    Item  := Trim(Item);
    HTMLDecode(Item);
    Comments := Comments + 'Fecha de estreno: ' + Item +#13#10;
  // Fecha de lanzamiento
   LineNr := FindLine('Fecha de lanzamiento:</b>  <font class=colorcitodenuri>', Page, 0);
    Item := copy(Page.Text, pos('Fecha de lanzamiento:</b>  <font class=colorcitodenuri>',Page.Text), length(Page.Text));
    Item := TextBetween (Item, 'Fecha de lanzamiento:</b>  <font class=colorcitodenuri>', '</font><BR>');
    DeleteTags (Item);
    Item  := Trim(Item);
    HTMLDecode(Item);
    Comments := Comments + 'Fecha de Lanzamiento: '+Item+#13#10;
  // Precio
   LineNr := FindLine('Precio:</b>  <font class=colorcitodenuri>', Page, 0);
    Item := copy(Page.Text, pos('Precio:</b>  <font class=colorcitodenuri>',Page.Text), length(Page.Text));
    Item := TextBetween (Item, 'Precio:</b>  <font class=colorcitodenuri>', '</font><BR>');
    DeleteTags (Item);
    Item  := Trim(Item);
    HTMLDecode(Item);
    Comments := Comments + 'Precio: '+Item+#13#10;
  // Categoria
  LineNr := FindLine('<b>Género: </b>', Page, 0);
  if LineNr > 0 then
    Item := copy(Page.Text, pos('<b>Género: </b>',Page.Text), length(Page.Text));
    Item := TextBetween (Item, '<b>Género: </b>', '.<br');
    HTMLDecode(Item);
  //caratula pequeña
  LineNr := FindLine('<img src="img_dvd/', Page, 0);
     Line := Page.GetString(Linenr);
     Item := TextBetween (Line, '<img src="img_dvd/', '" width');
     GetPicture ('http://www.comohacercine.com/img_dvd/'+Item);
//end;
Input('Comohacercine', 'Buscar:', MovieName);
     if(GetOption('Sin resultado') = 0) then  Input('Comohacercine', 'Buscar:', MovieName);
   AnalyzePage('http://www.google.es/search?num=100&hl=es&as_qdr=all&q=allinanchor%3A++%22' + UrlEncode(MovieName)+'%22+site%3Awww.comohacercine.com&btnG=B%C3%BAsqueda&meta=');
