Nuevo script Cinefantastico(ES)v1.0
legrad
Post by legrad »
Authors=Legrad
Title=Cinefantastico(ES)
Description=cine
Site=www.cinefantastico.com
Language=ES
Version=1.0
Requires=3.5.0
Comments=
License=
 program cinefantastico;
  MovieURL: string;
function UpFirstLetterWord(texto:string):string;
var espaco:integer;
sst:string;
texto:=AnsiUpFirstLetter(AnsiLowerCase(texto));
    espaco:=Pos(' ',texto);
    sst:=AnsiUpperCase(Copy(texto,espaco+1,1));
texto:=Copy(texto,1,espaco-1)+'/|\'+sst+Copy(texto,espaco+2,length(texto));
until Pos(' ',texto)=0;
texto := StringReplace(texto, '/|\', ' ');
if Copy(texto,1,1)=' ' then
  texto:=Copy(texto,2,length(texto));
result:=texto;
   n,len, tag: Integer;
   c: char;
   t: String;
   tag := 0;
   t := '';
   len := length(s);
   for n :=1 to len do
     c := Copy(s,n,1);
     // quitamos las comillas
     if c = '''' then
        c := ' ';
        t := t + c;
   s := t;
   result := t;
function Acentos(str1: string) :string;
          str1 := StringReplace(str1, 'Ö' , 'Ö');
          str1 := StringReplace(str1, 'ö' , 'ö');
          str1 := StringReplace(str1, 'Ã￾' , 'À');
          str1 := StringReplace(str1, 'É' , 'É');
          str1 := StringReplace(str1, 'é' , 'é');
          str1 := StringReplace(str1, 'Ã￾', 'Í');
          str1 := StringReplace(str1, 'Ó' , 'Ó');
          str1 := StringReplace(str1, 'Ñ' , 'Ñ');
          str1 := StringReplace(str1, 'á' , 'à');
          Str1 := StringReplace(Str1, ''', '');
          Str1 := StringReplace(Str1, 'Ñ©', 'é');
          Str1 := StringReplace(Str1, '&', '&');
          Str1 := StringReplace(Str1, 'ó', 'ó');
          Str1 := StringReplace(Str1, 'Ú', 'ú');
          Str1 := StringReplace(Str1, 'ë', 'ë');
          Str1 := StringReplace(Str1, '-', ' ');
          Str1 := StringReplace(Str1, '()', '');
          Str1 :=UpFirstLetterWord(Str1);
result := str1;
  Result := -1;
  if StartAt < 0 then
    StartAt := 0;
      Result := i;
  InitialPos: Integer;
  if InitialPos = 0 then
    result := ''
    InitialPos := Pos(EndTag, S);
      result := S
      Delete(S, 1, InitialPos + 1);
   c: char;
   t: String;
   tag := 0;
   t := '';
   len := length(s);
   for n :=1 to len do
      c := Copy(s,n,1);
      if c = #9 then
         c := ' ';
      if(tag=1) then
         if(c='>') then tag := 0;
         continue;
         if(c='<') then
            tag := 1;
            continue;
         t := t + c;
   s := t;
   result := t;
  BeginPos, EndPos: Integer;
  BeginPoss, EndPoss: Integer;
  strPage := GetPage(Address);
  BeginPos := Pos('en el dominio <b>cinefantastico.com', strPage);
  if(BeginPos > -1)then
      Delete(strPage, 1, BeginPos);
      BeginPos := Pos('href="http://www.cinefantastico.com/film.php?id=', strPage);
      EndPos := 1;
          EndPos := Pos('" clas', strPage);
          MovieId := Copy(strPage,+48, EndPos-48);
          MovieAddr := 'http://www.cinefantastico.com/film.php?id=' + MovieId;
          BeginPoss := Pos(')">',strPage);
          EndPoss := Pos('</h2>', strPage);
          DeleteTags(MovieTitle);
          MovieTitle := TextBetween (MovieTitle, 'CineFantastico.com:', '</a>');
          MovieTitle := Acentos(MovieTitle);
          PickTreeAdd(MovieTitle,  MovieAddr);
           BeginPos := -1;
    PickTreeExec(Address)
    AnalyzeMoviePage(Address);
  Item: string;
  Comments: string;
  Actors: string;
  Directors: string;
  Description: string;
  Description := '';
  // URL
  // Titulo Traducido
  LineNr := FindLine('<title>CineFantastico.com:', Page, 0);
  Item := TextBetween (Line, '<title>CineFantastico.com:', '</title>');
  Item :=UpFirstLetterWord(Item);
  HTMLDecode(Item);
  // Titulo Original
  LineNr := FindLine('<u><i>Título original:</i></u>', Page, 0);
  if LineNr <> -1 then
    Item := TextBetween (Line, '<u><i>Título original:</i></u>', '<br>');
    DeleteTags (Item);
    HTMLDecode(Item);
  // Año
  LineNr := FindLine('u><i>Año:</i></u>', Page, 0);
  if LineNr > 0 then
    Item := copy(Page.Text, pos('u><i>Año:</i></u>',Page.Text), length(Page.Text));
    Item := TextBetween (Item, 'u><i>Año:</i></u>', '<br>');
    DeleteTags (Item);
    Item  := Trim(Item );
  // Productor
  LineNr := FindLine('<u><i>Compañía:', Page, 0);
  if LineNr > 0 then
    Item := copy(Page.Text, pos('<u><i>Compañía:',Page.Text), length(Page.Text));
    Item := TextBetween (Item, '</i></u>', '<br>');
    DeleteTags (Item);
  // Duracion
  LineNr := FindLine('<td valign=top width=478>', Page, 0);
  if LineNr > 0 then
    Item := copy(Page.Text, pos('<br>Duración',Page.Text), length(Page.Text));
    Item := TextBetween (Item, '<b>', 'minutos');
    Item := StringReplace(Item , #13#10, '');
    DeleteTags (Item);
  // Nacionalidad
  if LineNr > 0 then
    Item := copy(Page.Text, pos('<td valign=top width=478>',Page.Text), length(Page.Text));
    Item := TextBetween (Item, '</b><br>País ................................ <b>', '</b><br>');
    Item  := StringReplace(Item , '   ', '');
    DeleteTags (Item);
    Item   := AnsiUpFirstLetter(Item );
  // Género
  if LineNr > 0 then
    Item := TextBetween (Item, '</b><br>Género ............................ <b>', '</b><br>');
    DeleteTags (Item);
  // Director
  LineNr := FindLine('<u><i>Director:</i></u>', Page, 0);
    Item := TextBetween (Line, '<u><i>Director:</i></u>', '<br>');
    DeleteTags (Item);
    HTMLDecode(Item);
  // Reparto
  LineNr := FindLine('<u><i>Reparto:', Page, 0);
  if LineNr > 0 then
    Item := copy(Page.Text, pos('<u><i>Reparto:',Page.Text), length(Page.Text));
    Item := TextBetween (Item, '</i></u><br>', '</td>');
    Item := StringReplace(Item ,#13#10, ', ');
    //Item  := StringReplace(Item , '<br>',#13#10);
    //Item  := StringReplace(Item , '   ', '');
    DeleteTags (Item);
  // Comentarios
  LineNr := FindLine('<b><u>Comentario:', Page, 0);
  if LineNr > 0 then
    Item := copy(Page.Text, pos('<b><u>Comentario:',Page.Text), length(Page.Text));
    Item := TextBetween (Item, '</u></b><br>', '</table>');
    Item := StringReplace(Item ,#13#10, '');
    DeleteTags (Item);
    HTMLDecode(Item);
    SetField(fieldComments, Trim (Item));
  // Sinopsis
  LineNr := FindLine('<b><u>Sinopsis:</u>', Page, 0);
  if LineNr > 0 then
    Item := copy(Page.Text, pos('<b><u>Sinopsis:</u>',Page.Text), length(Page.Text));
    Item := TextBetween (Item, '</b><br>', '<table width="100%">');
    DeleteTags (Item);
    HTMLDecode(Item);
// Picture
  LineNr := FindLine('"><img src="images/', Page, 0);
     Item := TextBetween (Line, '"><img src="images/', 'th.jpg"');
     GetPicture ('http://www.cinefantastico.com/images/'+Item+'ct.jpg');
Input('Cinefantastico', 'Buscar:', MovieName);
     if(GetOption('Sin resultado') = 0) then  Input('Cinefantastico', 'Buscar', MovieName);
   AnalyzePage('http://www.google.com/custom?hl=es&ie=ISO-8859-1&oe=ISO-8859-1&client=pub-8487308407021333&cof=FORID%3A1%3BGL%3A1%3BS%3Ahttp%3A%2F%2Fwww.cinefantastico.com%3BL%3Ahttp%3A%2F%2Fwww.cinefantastico.com%2Findice2a.jpg%3BLH%3A50%3BLW%3A193%3BLBGC%3A000000%3BBGC%3A%23000000%3BT%3A%23ff9933%3BLC%3A%23ff3300%3BVLC%3A%23ff0066%3BGALT%3A%23FF3333%3BGFNT%3A%23cc3333%3BGIMP%3A%23cc3333%3BDIV%3A%23CC3300%3B&domains=CineFantastico.com&q=' + UrlEncode(MovieName)+'&btnG=B%FAsqueda&sitesearch=CineFantastico.com');
