Update Abandomoviez(ES)v1.0 to v1.1
legrad
Post by legrad »
Authors=Legrad
Title=Abandomoviez(ES)
Description=
Site=www.abandomoviez.net
Language=ES
Version=1.1
Requires=3.5.0
Comments=
License=
program Abandomoviez;
  MovieURL: string;
function UpFirstLetterWord(texto:string):string;
var espaco:integer;
sst:string;
texto:=AnsiUpFirstLetter(AnsiLowerCase(texto));
    espaco:=Pos(' ',texto);
    sst:=AnsiUpperCase(Copy(texto,espaco+1,1));
texto:=Copy(texto,1,espaco-1)+'/|\'+sst+Copy(texto,espaco+2,length(texto));
until Pos(' ',texto)=0;
texto := StringReplace(texto, '/|\', ' ');
if Copy(texto,1,1)=' ' then
  texto:=Copy(texto,2,length(texto));
result:=texto;
  Result := -1;
  if StartAt < 0 then
    StartAt := 0;
      Result := i;
  InitialPos: Integer;
  if InitialPos = 0 then
    result := ''
    InitialPos := Pos(EndTag, S);
      result := S
      Delete(S, 1, InitialPos + 1);
   n,len, tag: Integer;
   c: char;
   t: String;
   tag := 0;
   t := '';
   len := length(s);
   for n :=1 to len do
      c := Copy(s,n,1);
      if c = #9 then
         c := ' ';
      if(tag=1) then
         if(c='>') then tag := 0;
         continue;
         if(c='<') then
            tag := 1;
            continue;
         t := t + c;
   s := t;
   result := t;
  BeginPos, EndPos: Integer;
  BeginPoss, EndPoss: Integer;
  strPage := GetPage(Address);
  BeginPos := Pos(' en el dominio <b>www.abandomoviez.net', strPage);
  if(BeginPos > -1)then
      Delete(strPage, 1, BeginPos);
      BeginPos := Pos('href="http://www.abandomoviez.net/db/pelicula.php?film=', strPage);
      EndPos := 1;
          MovieId := Copy(strPage,+55, EndPos-55);
          MovieAddr := 'http://www.abandomoviez.net/db/pelicula.php?film=' + MovieId;
          BeginPoss := Pos(')">',strPage);
          EndPoss := Pos('</a>', strPage);
          MovieTitle  := TextBetween(MovieTitle , 'cula:', '(');
          MovieTitle  := StringReplace(MovieTitle , 'á', 'á');
          MovieTitle  := StringReplace(MovieTitle , 'é', 'é');
          MovieTitle  := StringReplace(MovieTitle , 'í', 'í');
          MovieTitle  := StringReplace(MovieTitle , 'ó', 'ó');
          MovieTitle  := StringReplace(MovieTitle , 'ú', 'ú');
          MovieTitle  := StringReplace(MovieTitle , 'É', 'É');
          MovieTitle  := StringReplace(MovieTitle , 'Ó', 'Ó');
          MovieTitle  := StringReplace(MovieTitle , 'Â', '');
          MovieTitle  := StringReplace(MovieTitle , 'ñ', 'ñ');
          MovieTitle  := StringReplace(MovieTitle , 'Ã￾', 'Á');
          MovieTitle  := StringReplace(MovieTitle , 'Ú', 'Ú');
          MovieTitle  := UpFirstLetterWord(MovieTitle);
          DeleteTags(MovieTitle);
          PickTreeSort;
           BeginPos := -1;
    PickTreeExec(Address)
    AnalyzeMoviePage(Address);
  Item: string;
  Comments: string;
  Actors: string;
  Directors: string;
  Description: string;
  Busca: integer;
  Description := '';
  Comments := '';
  // URL
  // Titulo traducido
  LineNr := FindLine('<title>Película:', Page, 0);
  Item := TextBetween (Line, '<title>Película:', '(');
  HTMLDecode(Item);
  // Titulo Original
  if LineNr <> -1 then
    Item := TextBetween (Line, '(', ')');
    HTMLDecode(Item);
  // Categoria
  LineNr := FindLine('GENERO</td>', Page, 0);
  if LineNr > 0 then
    Item := copy(Page.Text, pos('GENERO</td>',Page.Text), length(Page.Text));
    Item := TextBetween (Item, '66">', '</td>');
    Item  := Trim(Item );
    HTMLDecode(Item);
   // pais
  LineNr := FindLine('PAIS</td>', Page, 0);
  if LineNr > 0 then
    Item := copy(Page.Text, pos('PAIS</td>',Page.Text), length(Page.Text));
    Item  := StringReplace(Item , 'Estados Unidos', 'USA');
    Item  := StringReplace(Item , 'EE.UU.', 'USA');
    Item  := StringReplace(Item , 'E.E.U.U.', 'USA');
    Item   := AnsiUpFirstLetter(Item );
    HTMLDecode(Item);
  // Duracion
  LineNr := FindLine('DURACION</td>', Page, 0);
  if LineNr > 0 then
    Item := copy(Page.Text, pos('DURACION</td>',Page.Text), length(Page.Text));
    Item := TextBetween (Item, '66">', 'Min.');
    HTMLDecode(Item);
  // año
  LineNr := FindLine('AÑO</td>', Page, 0);
  if LineNr > 0 then
    Item := copy(Page.Text, pos('AÑO</td>',Page.Text), length(Page.Text));
    HTMLDecode(Item);
  // director
  LineNr := FindLine('DIRECTOR:</td>', Page, 0);
  if LineNr > 0 then
    Item := copy(Page.Text, pos('DIRECTOR:</td>',Page.Text), length(Page.Text));
    Item := TextBetween (Item, 'film=', '">');
    HTMLDecode(Item);
  // Reparto
  LineNr := FindLine('INTERPRETES</td>', Page, 0);
  if LineNr > 0 then
    Item := copy(Page.Text, pos('INTERPRETES</td>',Page.Text), length(Page.Text));
    Item := TextBetween (Item, '">', '</tr>');
    DeleteTags(Item);
    HTMLDecode(Item);
   // productor
  LineNr := FindLine('PRODUCTOR</td>', Page, 0);
  if LineNr > 0 then
    Item := copy(Page.Text, pos('PRODUCTOR</td>',Page.Text), length(Page.Text));
    Item := TextBetween (Item, '">', '</a>');
    DeleteTags(Item);
    HTMLDecode(Item);
  // sinopsis
 LineNr := FindLine('SINOPSIS: </strong>', Page, 0);
  if LineNr > 0 then
    Item := copy(Page.Text, pos('SINOPSIS: </strong>',Page.Text), length(Page.Text));
    Item := TextBetween (Item, '"justify">', '</p></td>');
    Item := StringReplace(Item , #13#10, '');
    DeleteTags (Item);
    HTMLDecode(Item);
   // Guión
   LineNr := FindLine('GUION</td>', Page, 0);
    Item := copy(Page.Text, pos('GUION</td>',Page.Text), length(Page.Text));
    DeleteTags (Item);
    Item  := Trim(Item);
    HTMLDecode(Item);
    Comments := Comments + 'Guión: ' + Item +#13#10;
  // Fotografía
   LineNr := FindLine('FOTOGRAFÍA</td>', Page, 0);
    Item := copy(Page.Text, pos('FOTOGRAFÍA</td>',Page.Text), length(Page.Text));
    Item := TextBetween (Item, '">', '<tr>');
    DeleteTags (Item);
    Item  := Trim(Item);
    HTMLDecode(Item);
    Comments := Comments + 'Fotografía: ' + Item +#13#10;
  // MONTAJE
   LineNr := FindLine('MONTAJE</td>', Page, 0);
    Item := copy(Page.Text, pos('MONTAJE</td>',Page.Text), length(Page.Text));
    DeleteTags (Item);
    Item  := Trim(Item);
    HTMLDecode(Item);
    Comments := Comments + 'Montaje: ' + Item +#13#10;
  // Estreno en cine
   LineNr := FindLine('ESTRENO EN CINE:</td>', Page, 0);
    Item := copy(Page.Text, pos('ESTRENO EN CINE:</td>',Page.Text), length(Page.Text));
    Item := TextBetween (Item, '">', '</td>');
    DeleteTags (Item);
    Item  := Trim(Item);
    HTMLDecode(Item);
    Comments := Comments + 'Estreno en Cine: ' + Item +#13#10;
  // Estreno en DVD
   LineNr := FindLine('ESTRENO EN DVD:</td>', Page, 0);
    Item := copy(Page.Text, pos('ESTRENO EN DVD:</td>',Page.Text), length(Page.Text));
    DeleteTags (Item);
    Item  := Trim(Item);
    HTMLDecode(Item);
    Comments := Comments + 'Estreno en DVD: ' + Item +#13#10;
  // Trailer
   LineNr := FindLine('Trailer OnLine</div>', Page, 0);
    Item := copy(Page.Text, pos('Trailer OnLine</div>',Page.Text), length(Page.Text));
    Item := TextBetween (Item, 'value="', '"></param>');
    DeleteTags (Item);
    Item  := Trim(Item);
    HTMLDecode(Item);
    Comments := Comments + 'Trailer: ' + Item +#13#10;
  // Caratula
  LineNr := FindLine('src="foto/', Page, 0);
    Item := copy(Page.Text, pos('src="foto/',Page.Text), length(Page.Text));
    Item := TextBetween (Item, 'src="', '" width');
    HTMLDecode(Item);
    Item := StringReplace (Item, ' ', '%20');
    GetPicture ('http://www.abandomoviez.net/db/'+Item);
//end;
Input('Abandomoviez', 'Buscar:', MovieName);
     if(GetOption('Sin resultado') = 0) then  Input('Abandomoviez', 'Buscar:', MovieName);
   AnalyzePage('http://www.google.es/search?num=100&hl=es&as_qdr=all&q=allinanchor%3A'+UrlEncode(MovieName)+'+site%3Awww.abandomoviez.net%2Fdb%2F&btnG=B%C3%BAsqueda&meta=');
