wrong mediainfo.dll in 3.5.1?
johndough
Post by johndough »
hi there, I installed amc 3.5.1
when trying to import from an mp4 it says:
"mediainfo.dll wrong version. expected "0.7" but found "0.6.0.0".
I installed mediainfo 0.7.4.7 - but that didnt change a thing.
so, what did I do wrong and how can I fix it?
thanks a lot in advance,
j.
Two lines below the download link of AMC 3.5.1 there is the link for the matching MediaInfo version.
Though that 0.7.4.7 should work. What message did it show with that one?
johndough
Post by johndough »
download (from sourceforge) and install didnt change anything - still the same "expected 0.7, found 0.6.0.0"
oh, maybe I should mention that Im on vista :)
If it finds 0.6 it means that the "mediainfo.dll" file in the AMC folder is the 0.6... did you replace/overwrite the file?
johndough
Post by johndough »
duh ... replaced the mediainfo.dll in the amc-folder manually and it works ... :/
many thanks for fast, friendly and precise support btw :)
and for the great program without which Id be lost ...
