Media Label Suggestion
buffyiscool
Post by buffyiscool »
Hi there
Would it be possible to change the Media Label input box to a drop down that lists any media labels already used. This would be useful for those of us that store a number of movies etc on 1 dvd as it would ensure that the correct media label name/number is entered.
I found that if one letter was entered wrong into the media label field then the film would be shown as being on a different disc.
Hope you understand what I'm after.
Keep up the good work.
Indeed that could be done in a future version.
buffyiscool
RE: Media Label Suggestion
Hi antp
Thanks very much.
Kindest Regards
