PHP & AMC, Revisited
smalltux
Post by smalltux »
For all those who want to export movies from their AMC database to a PHP+MySQL enabled website (in a very simple way), here is my solution:
http://www.luka2002.com/movies
Just take a look... If you like it, I'll post my procedures and advices here :) If not, well... I like it, that's enough :D
I apologize to the author of AMC for not mentioning his great piece of software on my webiste, but it will be rectified in a day or two.
Nice list.
No problem for not mentioning the program on the site, you are not forced to do that ;)
miku
I'm interested in it
Post by miku »
Hi Smalltux,
I'm interested in export the antp script into a php class or functions.
Can you help me?
thanks
You mean the scripts that get info from internet? You cannot "export" that, you just have to rewrite the code in PHP, i.e. translate it manually.
shadowbikes
Post by shadowbikes »
Hi smalltux,
Looks great, when will you upload these file's, or send it to my e-mail adres.
thnx Rene
micmou2
Post by micmou2 »
hi smalltux,
will you upload your files?
thanx
