Folder rename
FD4347
Folder rename
Post by FD4347 »
Hello,
is it possible to rename folder-names?
Have somebody any ideas?
Det
:??: yes it is possible, you have to add these to the list by drag & drop or using "Add folders" button, and checking the "add selected folders" option.
