Desperately Need help w/ MPAA
zxao
Post by zxao »
So I've got a pretty large movie collection and i REALLY need mpaa ratings tagged to these. I've tried everything that i have read using the imdb script and i cant get it to get that info.
I have no problem getting all the rest of the info. its only the mpaa info thats giving me such a hard time. I know i must be doing something wrong so if someone would please tell me how to get the ratings i would really be grateful.
Do you use the latest IMDB script? It has an option called "MPAA", what value did you select for that option?
What is the problem exactly, as I do not really see how I can solve a problem like what you described...
zxao
Post by zxao »
i d/l the version of the imdb script from the script page (would that one be the newest?) and i set the mpaa the tag in the media type field but it has never worked. the field is always blank.
Indeed there is a bug, it is my fault :D
I only tested with the MPAA rating in Comments field, which should work.
For the media field, I made a typo in the code.
Find the line
SetField(fieldMediaType, TextBetween(Value, 'Rater ', ' '))
and replace "Rater" by "Rated".
Or download the script from my server again, as I updated it.
