version modificada BaseCine(ES)V1.1
legrad
Post by legrad »
Arreglo en orden comentarios, y otros retoques
Authors=Legrad
Title=Cine-BaseCine
Description=
Site=www.basecine.net
Language=Cine
Version=1.1
Requires=3.5.0
Comments=
License=
 program BaseCine;
  MovieURL: string;
function UpFirstLetterWord(texto:string):string;
var espaco:integer;
sst:string;
texto:=AnsiUpFirstLetter(AnsiLowerCase(texto));
    espaco:=Pos(' ',texto);
    sst:=AnsiUpperCase(Copy(texto,espaco+1,1));
texto:=Copy(texto,1,espaco-1)+'/|\'+sst+Copy(texto,espaco+2,length(texto));
until Pos(' ',texto)=0;
texto := StringReplace(texto, '/|\', ' ');
if Copy(texto,1,1)=' ' then
  texto:=Copy(texto,2,length(texto));
result:=texto;
                              function FindLine(Pattern: string; List: TStringList;
StartAt: Integer): Integer;
  Result := -1;
  if StartAt < 0 then
    StartAt := 0;
      Result := i;
                      function TextBetween(var S: string; StartTag: string; EndTag:
string): string;
  InitialPos: Integer;
  if InitialPos = 0 then
    result := ''
    InitialPos := Pos(EndTag, S);
      result := S
      Delete(S, 1, InitialPos + 1);
   n,len, tag: Integer;
   c: char;
   t: String;
   tag := 0;
   t := '';
   len := length(s);
   for n :=1 to len do
     c := Copy(s,n,1);
     if c = '''' then
        c := ' ';
        t := t + c;
   s := t;
   result := t;
   c: char;
   t: String;
   tag := 0;
   t := '';
   len := length(s);
   for n :=1 to len do
      c := Copy(s,n,1);
      if c = #9 then
         c := ' ';
      if(tag=1) then
         if(c='>') then tag := 0;
         continue;
         if(c='<') then
            tag := 1;
            continue;
         t := t + c;
   s := t;
   result := t;
  BeginPos, EndPos: Integer;
  BeginPoss, EndPoss: Integer;
  strPage := GetPage(Address);
  BeginPos := Pos('resultados de búsqueda</b></font></td></tr>', strPage);
  if(BeginPos > -1)then
      Delete(strPage, 1, BeginPos);
      BeginPos := Pos('href=peli.php?id=', strPage);
      EndPos := 1;
          EndPos := Pos('><', strPage);
          MovieId := Copy(strPage,+17, EndPos-17);
          MovieAddr := 'http://www.basecine.net/peli.php?id=' + MovieId;
          BeginPoss := Pos('class=noticia',strPage);
          EndPoss := Pos('</a>', strPage);
          MovieTitle := Copy(strPage,BeginPoss+2, EndPoss);
          MovieTitle  := TextBetween(MovieTitle , '>', '</font>');
          MovieTitle  := UpFirstLetterWord(MovieTitle);
          DeleteTags(MovieTitle);
          MovieTitle:= StringReplace(MovieTitle ,#13#10, '');
          MovieTitle:= StringReplace(MovieTitle ,'   ', '');
          BeginPos := -1;
    PickTreeExec(Address)
    AnalyzeMoviePage(Address);
  Item: string;
  Comments: string;
  Actors: string;
  Directors: string;
  Description: string;
  Busca: integer;
  Description := '';
  Comments := '';
// URL
// Titulo traducido
  Item := TextBetween (Line, '<title>', ',');
  Item  := AnsiLowerCase(Item);
  Item  := AnsiUpFirstLetter(Item );
  HTMLDecode(Item);
// Titulo Original
  LineNr := FindLine('<b>Título original:</b>', Page, 0);
  if LineNr <> -1 then
    Item := TextBetween (Line, '<b>Título original:</b>', '<br>');
    HTMLDecode(Item);
// año
  LineNr := FindLine('<b>Año:</b> ', Page, 0);
    Item := TextBetween (Line, '<b>Año:</b> ','<br>');
    HTMLDecode(Item);
// Duracion
  LineNr := FindLine('<b>Duración:</b>', Page, 0);
  if LineNr > 0 then
    Item := copy(Page.Text, pos('<b>Duración:</b>',Page.Text), length(Page.Text));
    Item := TextBetween (Item, '<b>Duración:</b>', '<br>');
    Item  := Trim(Item );
    HTMLDecode(Item);
// Categoria
  LineNr := FindLine('<b>Género:</b> ', Page, 0);
  if LineNr > 0 then
    Item := copy(Page.Text, pos('<b>Género:</b> ',Page.Text), length(Page.Text));
    Item := TextBetween (Item, '<b>Género:</b> ', '<br>');
    HTMLDecode(Item);
// Reparto
  LineNr := FindLine('<b>Reparto:', Page, 0);
  if LineNr > 0 then
    Item := copy(Page.Text, pos('<b>Reparto:',Page.Text), length(Page.Text));
    Item := TextBetween (Item, '</b>', ', <br>');
    Item := StringReplace(Item , #13#10, '');
    DeleteTags (Item);
    HTMLDecode(Item);
// director
  LineNr := FindLine('<b>Dirección:', Page, 0);
  if LineNr > 0 then
    Item := copy(Page.Text, pos('<b>Dirección:',Page.Text), length(Page.Text));
    Item := TextBetween (Item, '</b>', '<br>');
    Item := StringReplace(Item , ',', '  ');
    DeleteTags (Item);
    HTMLDecode(Item);
// productor
  LineNr := FindLine('<b>Productor:', Page, 0);
  if LineNr > 0 then
    Item := copy(Page.Text, pos('<b>Productor:',Page.Text), length(Page.Text));
    DeleteTags (Item);
    HTMLDecode(Item);
// pais
  LineNr := FindLine('<b>Nacionalidad:</b>', Page, 0);
  if LineNr > 0 then
    Item := copy(Page.Text, pos('<b>Nacionalidad:</b>',Page.Text), length(Page.Text));
    Item  := StringReplace(Item , 'Estados Unidos', 'USA');
    Item  := StringReplace(Item , '-', ', ');
    DeleteTags (Item);
    HTMLDecode(Item);
// Calificación
  LineNr := FindLine('<div id="calificacion">', Page, 0);
  if LineNr > 0 then
    Item := copy(Page.Text, pos('<div id="calificacion">',Page.Text), length(Page.Text));
    Item := TextBetween (Item, '<div class="voto">', '</div>');
    Item  := StringReplace(Item , '  ', '');
    DeleteTags (Item);
    HTMLDecode(Item);
    SetField(fieldRating, Trim (Item));
// sinopsis
 LineNr := FindLine('<b>Sinopsis:', Page, 0);
  if LineNr > 0 then
    Item := copy(Page.Text, pos('<b>Sinopsis:',Page.Text), length(Page.Text));
    Item := TextBetween (Item, '<b>Sinopsis:', '<br></font></p>');
    DeleteTags (Item);
    HTMLDecode(Item);
// Compañía Productora
   LineNr := FindLine('<b>Compañía Productora:', Page, 0);
    Item := copy(Page.Text, pos('<b>Compañía Productora:',Page.Text),
length(Page.Text));
    DeleteTags (Item);
    Item  := Trim(Item);
    HTMLDecode(Item);
    Comments := Comments + 'Compañía Productora: ' + Item +#13#10;
// Distribuidora:
   LineNr := FindLine('<b>Distribuidora:', Page, 0);
    Item := copy(Page.Text, pos('<b>Distribuidora:',Page.Text), length(Page.Text));
    DeleteTags (Item);
    Item  := Trim(Item);
    HTMLDecode(Item);
    Comments := Comments + 'Distribuidora: ' + Item +#13#10;
// Distribuidora DVD
   LineNr := FindLine('Distribuidora DVD:', Page, 0);
    Item := copy(Page.Text, pos('Distribuidora DVD:',Page.Text), length(Page.Text));
    DeleteTags (Item);
    Item  := Trim(Item);
    HTMLDecode(Item);
    Comments := Comments + 'Distribuidora DVD: ' + Item +#13#10;
// Guión
   LineNr := FindLine('<b>Guión:', Page, 0);
    Item := copy(Page.Text, pos('<b>Guión:',Page.Text), length(Page.Text));
    Item := StringReplace (Item, '</a>,', '');
    DeleteTags (Item);
    Item  := Trim(Item);
    HTMLDecode(Item);
    Comments := Comments + 'Guión: ' + Item +#13#10;
// Fotografía
   LineNr := FindLine('<b>Fotografía:', Page, 0);
    Item := copy(Page.Text, pos('<b>Fotografía:',Page.Text), length(Page.Text));
    DeleteTags (Item);
    Item  := Trim(Item);
    HTMLDecode(Item);
    Comments := Comments + 'Fotografía: ' + Item +#13#10;
// Música
   LineNr := FindLine('<b>Música:', Page, 0);
    Item := copy(Page.Text, pos('<b>Música:',Page.Text), length(Page.Text));
    DeleteTags (Item);
    Item  := Trim(Item);
    HTMLDecode(Item);
    Comments := Comments + 'Música: ' + Item +#13#10;
// Montaje:
   LineNr := FindLine('<b>Montaje:', Page, 0);
    Item := copy(Page.Text, pos('<b>Montaje:',Page.Text), length(Page.Text));
    DeleteTags (Item);
    Item  := Trim(Item);
    HTMLDecode(Item);
    Comments := Comments + 'Montaje: ' + Item +#13#10;
// Dirección artística:
   LineNr := FindLine('<b>Dirección artística:', Page, 0);
    Item := copy(Page.Text, pos('<b>Dirección artística:',Page.Text), length(Page.Text));
    Item := TextBetween (Item, '<b>Dirección artística:', '<br>');
    DeleteTags (Item);
    Item  := Trim(Item);
    HTMLDecode(Item);
    Comments := Comments + 'Dirección artística: ' + Item +#13#10;
// Recaudación:
   LineNr := FindLine('<b>Recaudación:</b>', Page, 0);
    Item := copy(Page.Text, pos('<b>Recaudación:</b>',Page.Text), length(Page.Text));
    Item := StringReplace(Item ,#13#10, '');
    DeleteTags (Item);
    Item  := Trim(Item);
    HTMLDecode(Item);
    Comments := Comments + 'Recaudación: ' + Item + #13#10;
// Espectadores:
   LineNr := FindLine('<b>Espectadores:', Page, 0);
    Item := copy(Page.Text, pos('<b>Espectadores:',Page.Text), length(Page.Text));
    DeleteTags (Item);
    Item  := Trim(Item);
    HTMLDecode(Item);
    Comments := Comments + 'Espectadores: ' + Item +#13#10;
// Fecha de Estreno:
   LineNr := FindLine('<b>Fecha de Estreno:', Page, 0);
    Item := copy(Page.Text, pos('<b>Fecha de Estreno:',Page.Text), length(Page.Text));
    DeleteTags (Item);
    Item  := Trim(Item);
    HTMLDecode(Item);
    Comments := Comments + 'Fecha de Estreno: ' + Item +#13#10;
// Trailer:
   LineNr := FindLine('<b>Trailer:', Page, 0);
    Item := copy(Page.Text, pos('<b>Trailer:',Page.Text), length(Page.Text));
    Item := TextBetween (Item, 'href=', 'target=');
    DeleteTags (Item);
    Item  := Trim(Item);
    HTMLDecode(Item);
    BorraComillas(Item);
    Comments := Comments + 'URL Trailer: ' + Item +#13#10;
// Clasificacion:
   LineNr := FindLine('<b>Clasificacion:', Page, 0);
    Item := copy(Page.Text, pos('<b>Clasificacion:',Page.Text), length(Page.Text));
    DeleteTags (Item);
    Item  := Trim(Item);
    HTMLDecode(Item);
    Comments := Comments + 'Clasificacion: ' + Item +#13#10;
// Ultima Actualización:
   LineNr := FindLine('<b>Ultima Actualización:', Page, 0);
    Item := copy(Page.Text, pos('<b>Ultima Actualización:',Page.Text), length(Page.Text));
    DeleteTags (Item);
    Item  := Trim(Item);
    HTMLDecode(Item);
    Comments := Comments + 'Ultima Actualización: ' + Item +#13#10;
// Fondo:
   LineNr := FindLine('<b>Fondo:', Page, 0);
    Item := copy(Page.Text, pos('<b>Fondo:',Page.Text), length(Page.Text));
    DeleteTags (Item);
    Item  := Trim(Item);
    HTMLDecode(Item);
    Comments := Comments + 'Fondo: ' + Item +#13#10;
// Premios:
   LineNr := FindLine('<b>Premios:', Page, 0);
    Item := copy(Page.Text, pos('<b>Premios:',Page.Text), length(Page.Text));
    DeleteTags (Item);
    Item  := Trim(Item);
    HTMLDecode(Item);
    Comments := Comments + 'Premios: ' + Item +#13#10;
// Complementos:
   LineNr := FindLine('<b>Complementos:', Page, 0);
    Item := copy(Page.Text, pos('<b>Complementos:',Page.Text), length(Page.Text));
    DeleteTags (Item);
    Item  := Trim(Item);
    HTMLDecode(Item);
    Comments := Comments + 'Complementos: ' + Item +#13#10;
// Caratula
  LineNr := FindLine('http://www.basecine.net/caratulas/', Page, 0);
    Item := copy(Page.Text, pos('http://www.basecine.net/caratulas/',Page.Text),
length(Page.Text));
    Item := TextBetween (Item, 'http://www.basecine.net/caratulas/', '.jpg');
    HTMLDecode(Item);
   GetPicture ('http://www.basecine.net/caratulas/'+Item+'.jpg');
  //HTMLDecode(Comments);
//end;
Input('BaseCine', 'Buscar:', MovieName);
     if(GetOption('Sin resultado') = 0) then  Input('BaseCine', 'Buscar:', MovieName);
   AnalyzePage('http://www.basecine.net/bilatu_peli1.php?titulo='
+UrlEncode(MovieName)+'&titulo_orig=&anho=&nacionalidad=&personai=&personad=&personag=');
Does this replace the previous "basecine" script ?
legrad
Post by legrad »
Yes, it is last script basecine
I am sorry to the botherments
No problem ;) Thank you very much for the scripts !
