Nuevo script Zinema-Legrad(ES)V1.0
legrad
Post by legrad »
Authors=Legrad
Title=ZinemaLegrad
Description=
Site=www.elitefreak.net
Language=ES
Version=1.0
Requires=3.5.0
Comments=
License=
program ZinemaLegrad;
 Uses StringUtils7552;
  MovieURL: string;
function UpFirstLetterWord(texto:string):string;
var espaco:integer;
sst:string;
texto:=AnsiUpFirstLetter(AnsiLowerCase(texto));
    espaco:=Pos(' ',texto);
    sst:=AnsiUpperCase(Copy(texto,espaco+1,1));
texto:=Copy(texto,1,espaco-1)+'/|\'+sst+Copy(texto,espaco+2,length(texto));
until Pos(' ',texto)=0;
texto := StringReplace(texto, '/|\', ' ');
if Copy(texto,1,1)=' ' then
  texto:=Copy(texto,2,length(texto));
result:=texto;
   n,len, tag: Integer;
   c: char;
   t: String;
   tag := 0;
   t := '';
   len := length(s);
   for n :=1 to len do
      c := Copy(s,n,1);
      // quitamos los tabuladores
      if c = #9 then
         c := ' ';
      if(tag=1) then
         if(c='>') then tag := 0;
         continue;
         if(c='<') then
            tag := 1;
            continue;
         t := t + c;
   s := t;
   result := t;
  strPage, strPages, MovieAddr, MovieTitle, MovieDate, MovieID: string;
  BeginPos, EndPos, BeginPo, EndPo: Integer;
  strPage := GetPage(Address);
  BeginPos := Pos(' en el dominio <b>www.zinema.com', strPage);
  if(BeginPos > -1)then
      Delete(strPage, 1, BeginPos);
      BeginPos := Pos('href="http://www.zinema.com/pelicula/', strPage);
      EndPos := 1;
          EndPos := Pos('.htm"', strPage);
          MovieId := Copy(strPage, +37, EndPos-37);
          MovieAddr := 'http://www.zinema.com/pelicula/' + MovieId+'.htm';
          BeginPos := Pos(')"',strPage);
          EndPos := Pos('</h2>', strPage);
          MovieTitle := Copy(strPage,BeginPos, EndPos);
          MovieTitle  := TextBetween (MovieTitle , '>', '</a>');
          MovieTitle  := StringReplace (MovieTitle , 'Ã￾', 'Á');
          MovieTitle  := StringReplace (MovieTitle , 'á', 'Á');
          MovieTitle  := StringReplace (MovieTitle , 'É', 'É');
          MovieTitle  := StringReplace (MovieTitle , 'Ó', 'Ó');
          MovieTitle  := StringReplace (MovieTitle , 'é', 'é');
          MovieTitle  := StringReplace (MovieTitle , 'Ã￾', 'Í');
          MovieTitle  := StringReplace (MovieTitle , 'ã￾', 'á');
          MovieTitle  := StringReplace (MovieTitle , 'í', 'í');
          MovieTitle  := StringReplace (MovieTitle , 'ó', 'ó');
          MovieTitle  := StringReplace (MovieTitle , 'ú', 'ú');
          MovieTitle  := StringReplace (MovieTitle , 'ZINEMA', '');
          MovieTitle  := StringReplace (MovieTitle , 'ñ', 'ñ');
          MovieTitle  := StringReplace (MovieTitle , ' - ', '');
          MovieTitle  := AnsiLowerCase(MovieTitle );
          MovieTitle  := UpFirstLetterWord(MovieTitle );
          HTMLRemoveTags(MovieTitle);
          PickTreeAdd(MovieTitle,MovieAddr);
          PickTreeSort;
           BeginPos := -1;
    PickTreeExec(Address)
    AnalyzeMoviePage(Address);
  Item: string;
  Comments: string;
  Actors: string;
  Directors: string;
  Description: string;
  BaseURL2: string;
  Beginpos: string;
  titre_film: string;
  EndPos: string;
  Movie: string;
  Description := '';
  Comments := '';
 // URL
   //Titulo Original
 LineNr := FindLine('original</strong>', Page, 0);
  if LineNr <> -1 then
    Item := copy(Page.Text, pos('original</strong>',Page.Text), length(Page.Text));
    Item := TextBetween (Item, 'original</strong>', '</tr>');
    Item  := StringReplace(Item ,#13#10,'');
    Item  := StringReplace(Item ,'  ',' ');
    Item  := Trim(Item );
    HTMLRemoveTags(Item);
    HTMLDecode(Item);
    Item  := UpFirstLetterWord(Item);
       //Titulo Traducido
    Item := copy(Page.Text, pos('<title>',Page.Text), length(Page.Text));
    Item := TextBetween (Item, '<title>', '</title>');
    Item  := StringReplace(Item ,'ZINEMA - ','');
    HTMLDecode(Item);
      // Año
  LineNr := FindLine('<strong>Año</strong>', Page, 0);
    Item := copy(Page.Text, pos('<strong>Año</strong>',Page.Text), length(Page.Text));
    Item := TextBetween (Item, '<strong>Año</strong>', '</tr>');
    DeleteTags(Item);
    HTMLDecode(Item);
    SetField(fieldYear, trim (Item));
      // Nacionalidad
  LineNr := FindLine('Nacionalidad</strong>', Page, 0);
    Item := copy(Page.Text, pos('Nacionalidad</strong>',Page.Text), length(Page.Text));
    Item := TextBetween (Item, 'color="#666666', '</tr>');
    Item  := StringReplace(Item ,'     ','');
    DeleteTags(Item);
    HTMLDecode(Item);
    Item  := StringReplace(Item ,'">','');
    Item  := StringReplace(Item ,'-',', ');
    SetField(fieldCountry, trim (Item));
  //Género
 LineNr := FindLine('<strong>Género</strong>', Page, 0);
    Item := copy(Page.Text, pos('<strong>Género</strong>',Page.Text), length(Page.Text));
    Item := TextBetween (Item, '<strong>Género</strong>', '</tr>');
    DeleteTags(Item);
    SetField(fieldCategory, trim (Item));
       //Duracion
 LineNr := FindLine('Duración</strong>', Page, 0);
    Item := copy(Page.Text, pos('Duración</strong>',Page.Text), length(Page.Text));
    Item := TextBetween (Item, 'Duración</strong>', '</tr>');
    Item  := StringReplace(Item ,'m.','');
    DeleteTags(Item);
    HTMLDecode(Item);
    SetField(fieldLength, trim (Item));
      // Director
  LineNr := FindLine('<strong>Dirección</strong>', Page, 0);
    Item := copy(Page.Text, pos('<strong>Dirección</strong>',Page.Text), length(Page.Text));
    Item := TextBetween (Item, '<strong>Dirección</strong>', '</tr>');
    DeleteTags(Item);
    HTMLDecode(Item);
    SetField(fieldDirector, trim (Item));
      // Reparto
  LineNr := FindLine('Intérpretes</strong>', Page, 0);
    Item := copy(Page.Text, pos('Intérpretes</strong>',Page.Text), length(Page.Text));
    Item := TextBetween (Item, '<strong>', 'Guión</strong>');
    Item  := StringReplace(Item ,')',')*');
    Item  := StringReplace(Item ,'*',#13#10);
    DeleteTags(Item);
    HTMLDecode(Item);
    SetField(fieldActors, trim (Item));
  //Sinopsis
  LineNr := FindLine('Sinopsis</strong>', Page, 0);
    Item := copy(Page.Text, pos('Sinopsis</strong>',Page.Text), length(Page.Text));
    Item := TextBetween (Item, 'color="#666666', '</font>');
    Item  := StringReplace(Item ,#13#10,' ');
    DeleteTags(Item);
    HTMLDecode(Item);
  // Guión
 LineNr := FindLine('Guión</strong>', Page, 0);
    Item := copy(Page.Text, pos('Guión</strong>',Page.Text), length(Page.Text));
    Item := TextBetween (Item, 'Guión</strong>', '<td width="15%"></td>');
    Item  := StringReplace(Item ,#13#10#,'');
    DeleteTags(Item);
    HTMLDecode(Item);
    Comments := Comments + 'Guión: '+Item+#13#10;
  // Fotografia
   LineNr := FindLine('Fotografía</strong>', Page, 0);
    Item := copy(Page.Text, pos('Fotografía</strong>',Page.Text), length(Page.Text));
    Item := TextBetween (Item, 'Fotografía</strong>', '</tr>');
    Comments := Comments + 'Fotografía: ' + Item + #13#10;
  // Música
   LineNr := FindLine('Música</strong>', Page, 0);
    Item := copy(Page.Text, pos('Música</strong>',Page.Text), length(Page.Text));
    Item := TextBetween (Item, 'Música</strong>', '</tr>');
    Comments := Comments + 'Música: ' + Item + #13#10;
   // Montaje
   LineNr := FindLine('Montaje</strong>', Page, 0);
    Item := copy(Page.Text, pos('Montaje</strong>',Page.Text), length(Page.Text));
    Item := TextBetween (Item, 'Montaje</strong>', '</tr>');
    Comments := Comments + 'Montaje: ' + Item + #13#10+'------------------------------------'+#13#10;
  // Pros y contras
   LineNr := FindLine('<strong>Contra</strong>', Page, 0);
    Item := copy(Page.Text, pos('<strong>Contra</strong>',Page.Text), length(Page.Text));
    Item := TextBetween (Item, '<td width="4%" valign="top"></td>', '</table>');
    DeleteTags(Item);
    HTMLDecode(Item);
    Comments := Comments + 'Pros y contras: ' + Item +#13#10+'------------------------------------'+#13#10;
  // Referencia
   LineNr := FindLine('Referencias</font>', Page, 0);
    Item := copy(Page.Text, pos('Referencias</font>',Page.Text), length(Page.Text));
    Item := TextBetween (Item, 'Referencias</font>', '</table>');
    Item  := Trim(Item);
    DeleteTags(Item);
    HTMLDecode(Item);
    Comments := Comments + 'Referencias: ' + Item +#13#10;
  // Picture
  LineNr := FindLine('src="../../carteles/', Page, 0);
    Item := copy(Page.Text, pos('src="../../carteles/',Page.Text), length(Page.Text));
    Item := TextBetween (Item, 'src="../../carteles/', '" width');
    HTMLDecode(Item);
   GetPicture ('http://www.zinema.com/carteles/'+Item);
  HTMLDecode(Comments);
            Input('ZinemaLegrad', 'Buscar:', MovieName);
     if(GetOption('') = 0) then  Input('ZinemaLegrad', 'Buscar:', MovieName);
   AnalyzePage('http://www.google.es/search?num=100&hl=es&as_qdr=all&q=allinanchor%3A+' + UrlEncode(MovieName)+'+site%3Awww.zinema.com&btnG=B%C3%BAsqueda&meta=');
In the beginning it is mentionned "Site=www.elitefreak.net", I suppose that this should be changed to "Site=www.zinema.com"?
legrad
Post by legrad »
If you have reason, it is necessary to change
Sorry
RANICUAJO
Post by RANICUAJO »
Añadido a la colección. Ya le tenía ganas.
Gracias de nuevo
(Ya he cambiado la web de referencia y el reparto :lol: )
Xalu2
