Update AnimeFrozen(ES)v1.1
legrad
Post by legrad »
Problem when copy into the forum.
The post change the characters.
in previous post change the string on line 57
change this &#39 for is '
then the script not run
Solucionado
Authors=Legrad
Title=AnimeFrozen(ES)
Description=cine
Site=www.frozen-layer.com
Language=es
Version=1.0
Requires=3.5.0
Comments=
License=
 program AnimeFrozen;
  MovieURL: string;
function UpFirstLetterWord(texto:string):string;
var espaco:integer;
sst:string;
texto:=AnsiUpFirstLetter(AnsiLowerCase(texto));
    espaco:=Pos(' ',texto);
    sst:=AnsiUpperCase(Copy(texto,espaco+1,1));
texto:=Copy(texto,1,espaco-1)+'/|\'+sst+Copy(texto,espaco+2,length(texto));
until Pos(' ',texto)=0;
texto := StringReplace(texto, '/|\', ' ');
if Copy(texto,1,1)=' ' then
  texto:=Copy(texto,2,length(texto));
result:=texto;
   n,len, tag: Integer;
   c: char;
   t: String;
   tag := 0;
   t := '';
   len := length(s);
   for n :=1 to len do
     c := Copy(s,n,1);
     // quitamos las comillas
     if c = '''' then
        c := ' ';
        t := t + c;
   s := t;
   result := t;
function Acentos(str1: string) :string;
          str1 := StringReplace(str1, 'Ö' , 'Ö');
          str1 := StringReplace(str1, 'ö' , 'ö');
          str1 := StringReplace(str1, 'Ã￾' , 'À');
          str1 := StringReplace(str1, 'É' , 'É');
          str1 := StringReplace(str1, 'é' , 'é');
          str1 := StringReplace(str1, 'Ã￾', 'Í');
          str1 := StringReplace(str1, 'Ó' , 'Ó');
          str1 := StringReplace(str1, 'Ñ' , 'Ñ');
          str1 := StringReplace(str1, 'á' , 'à');
          Str1 := StringReplace(Str1, ''', '');
          Str1 := StringReplace(Str1, 'Ñ©', 'é');
          Str1 := StringReplace(Str1, '&', '&');
          Str1 := StringReplace(Str1, 'ó', 'ó');
          Str1 := StringReplace(Str1, 'Ú', 'ú');
          Str1 := StringReplace(Str1, 'ë', 'ë');
          Str1 := StringReplace(Str1, '-', ' ');
          Str1 := StringReplace(Str1, '()', '');
          Str1 :=UpFirstLetterWord(Str1);
result := str1;
  Result := -1;
  if StartAt < 0 then
    StartAt := 0;
      Result := i;
  InitialPos: Integer;
  if InitialPos = 0 then
    result := ''
    InitialPos := Pos(EndTag, S);
      result := S
      Delete(S, 1, InitialPos + 1);
   c: char;
   t: String;
   tag := 0;
   t := '';
   len := length(s);
   for n :=1 to len do
      c := Copy(s,n,1);
      if c = #9 then
         c := ' ';
      if(tag=1) then
         if(c='>') then tag := 0;
         continue;
         if(c='<') then
            tag := 1;
            continue;
         t := t + c;
   s := t;
   result := t;
  BeginPos, EndPos: Integer;
  BeginPoss, EndPoss: Integer;
  strPage := GetPage(Address);
  BeginPos := Pos('Resultado de la búsqueda', strPage);
  if(BeginPos > -1)then
      Delete(strPage, 1, BeginPos);
      BeginPos := Pos('href="/infoanime/anime/', strPage);
      EndPos := 1;
          EndPos := Pos('" onmouseover', strPage);
          MovieId := Copy(strPage,+23, EndPos-23);
          MovieAddr := 'http://www.frozen-layer.com/infoanime/anime/' + MovieId;
          BeginPoss := Pos('hideTooltip()"',strPage);
          EndPoss := Pos('</li>', strPage);
          DeleteTags(MovieTitle);
          MovieTitle := TextBetween (MovieTitle, '">', '</a>');
          MovieTitle := Acentos(MovieTitle);
          MovieTitle := StringReplace(MovieTitle , #13#10, '');
          PickTreeAdd(MovieTitle,  MovieAddr);
           BeginPos := -1;
    PickTreeExec(Address)
    AnalyzeMoviePage(Address);
  Item: string;
  Comments: string;
  Actors: string;
  Directors: string;
  Description: string;
  Comments := '';
  Description := '';
  // URL
   // Original
  LineNr := FindLine('<h1 class="an">', Page, 0);
  if LineNr <> -1 then
    Item := TextBetween (Line, '<h1 class="an">', '</h1>');
    DeleteTags (Item);
    HTMLDecode(Item);
    Item :=UpFirstLetterWord(Item);
  // Traducido
  LineNr := FindLine('<li><strong>Título en castellano:</strong>', Page, 0);
  Item := TextBetween (Line, '<li><strong>Título en castellano:</strong>', '</li>');
  Item := StringReplace(Item, 'á', ',a');
  Item := StringReplace(Item, 'é', 'é');
  Item := StringReplace(Item, 'í', 'í');
  Item := StringReplace(Item, 'ó', 'ó');
  Item := StringReplace(Item, 'ú', 'ú');
  HTMLDecode(Item);
  // Año
  LineNr := FindLine('<li><strong>Año:', Page, 0);
  if LineNr > 0 then
    Item := copy(Page.Text, pos('<li><strong>Año:',Page.Text), length(Page.Text));
    Item := TextBetween (Item, '</strong> ', '</li>');
    Item := StringReplace(Item , #13#10, '');
    Item  := StringReplace(Item , '   ', '');
    DeleteTags (Item);
    Item  := Trim(Item );
  // Productor
  LineNr := FindLine('<li><strong>Estudio:</strong>', Page, 0);
  if LineNr > 0 then
    Item := copy(Page.Text, pos('<li><strong>Estudio:</strong>',Page.Text), length(Page.Text));
    Item := TextBetween (Item, '<a href="#">', '</a></li>');
    DeleteTags (Item);
    Item   := AnsiUpFirstLetter(Item );
  // Género
  LineNr := FindLine('<li><strong>Género:', Page, 0);
  if LineNr > 0 then
    Item := copy(Page.Text, pos('<li><strong>Género:',Page.Text), length(Page.Text));
    Item := TextBetween (Item, '</strong>', '</li>');
    DeleteTags (Item);
    HTMLDecode(Item);
  // Sinopsis
  LineNr := FindLine('<li><strong>Mostrada:</strong>', Page, 0);
  if LineNr > 0 then
    Item := copy(Page.Text, pos('<li><strong>Mostrada:</strong>',Page.Text), length(Page.Text));
    Item := TextBetween (Item, '<p class="desc">', '</p>');
    DeleteTags (Item);
    HTMLDecode(Item);
    // Comentario1
  LineNr := FindLine('<li><strong>Licenciada:</strong>', Page, 0);
  if LineNr > 0 then
    Item := copy(Page.Text, pos('<li><strong>Licenciada:</strong>',Page.Text), length(Page.Text));
    Item := TextBetween (Item, '">', '</a></li>');
    DeleteTags (Item);
    HTMLDecode(Item);
    Comments := Comments + 'Licenciada: ' + Item + #13#10;
  // Comentario2
  LineNr := FindLine('<li><strong>Saga:</strong>', Page, 0);
  if LineNr > 0 then
    Item := copy(Page.Text, pos('<li><strong>Saga:</strong>',Page.Text), length(Page.Text));
    Item := TextBetween (Item, '"">', '</a></li>');
    DeleteTags (Item);
    HTMLDecode(Item);
    Comments := Comments + 'Saga: ' + Item + #13#10;
  // Picture
  LineNr := FindLine('<div id="datlef"><img src="/infoanime/avatars/', Page, 0);
     Item := TextBetween (Line, '<div id="datlef"><img src="/infoanime/avatars/', '" class');
     GetPicture ('http://www.frozen-layer.com/infoanime/avatars/'+Item);
Input('AnimeFrozen', 'Buscar:', MovieName);
     if(GetOption('Sin resultado') = 0) then  Input('AnimeFrozen', 'Buscar', MovieName);
   AnalyzePage('http://www.frozen-layer.com/infoanime/busqueda/' + UrlEncode(MovieName));
NeoQueen
Post by NeoQueen »
Funciona perfecto :grinking:
Gracias!!!
Re: Update AnimeFrozen(ES)v1.1
legrad wrote: The post change the characters.
It is annoying indeed.
You have to type
& # 38; # 39; (without the spaces) so it is displayed as '
Another solution would be to use the procedure HtmlDecode rather than a stringreplace to handle these HTML entities.
Another remark: the remaining of your "Acentos" function could simply be replaced by the function UTF8Decode. It would probably be more reliable, as it would handle more cases ;)
legrad
Post by legrad »
Thank you for the tip, I try the tip.
Only I am an apprentice.
Greetings
