En Comentarios se carga el vinculo al trailer del dvd si lo contiene, en algunos hay trailer.
Authors=Legrad
Title=Maesen Adulto
Description=cine X
Site=
Language=ES
Version=1.0
Requires=3.5.0
Comments=
License=
program maesen;
MovieURL: string;
function UpFirstLetterWord(texto:string):string;
var espaco:integer;
sst:string;
texto:=AnsiUpFirstLetter(AnsiLowerCase(texto));
espaco:=Pos(' ',texto);
sst:=AnsiUpperCase(Copy(texto,espaco+1,1));
texto:=Copy(texto,1,espaco-1)+'/|\'+sst+Copy(texto,espaco+2,length(texto));
until Pos(' ',texto)=0;
texto := StringReplace(texto, '/|\', ' ');
if Copy(texto,1,1)=' ' then
texto:=Copy(texto,2,length(texto));
result:=texto;
n,len, tag: Integer;
c: char;
t: String;
tag := 0;
t := '';
len := length(s);
for n :=1 to len do
c := Copy(s,n,1);
if c = '''' then
c := ' ';
t := t + c;
s := t;
result := t;
Result := -1;
if StartAt < 0 then
StartAt := 0;
Result := i;
InitialPos: Integer;
if InitialPos = 0 then
result := ''
InitialPos := Pos(EndTag, S);
result := S
Delete(S, 1, InitialPos + 1);
c: char;
t: String;
tag := 0;
t := '';
len := length(s);
for n :=1 to len do
c := Copy(s,n,1);
if c = #9 then
c := ' ';
if(tag=1) then
if(c='>') then tag := 0;
continue;
if(c='<') then
tag := 1;
continue;
t := t + c;
s := t;
result := t;
BeginPos, EndPos: Integer;
BeginPoss, EndPoss: Integer;
strPage := GetPage(Address);
BeginPos := Pos('en el dominio <b>www.maesen.com', strPage);
if(BeginPos > -1)then
Delete(strPage, 1, BeginPos);
BeginPos := Pos('href="http://www.maesen.com/sexshop/plantilla.php?id=', strPage);
EndPos := 1;
MovieId := Copy(strPage,+53, EndPos-53);
MovieAddr := 'http://www.maesen.com/sexshop/plantilla.php?id=' + MovieId;
BeginPoss := Pos(')">',strPage);
EndPoss := Pos('</h2>', strPage);
MovieTitle := TextBetween (MovieTitle, 'La Sexshop en Casa //', '-');
DeleteTags(MovieTitle);
MovieTitle := UpFirstLetterWord(MovieTitle);
MovieTitle := StringReplace(MovieTitle , '’', 's');
MovieTitle := StringReplace(MovieTitle , 'À', 'á');
MovieTitle := StringReplace(MovieTitle , '㉑', 'é');
MovieTitle := StringReplace(MovieTitle , 'ã“', 'ó');
MovieTitle := StringReplace(MovieTitle , 'ã‘', 'ñ');
MovieTitle := StringReplace(MovieTitle , 'ã‡', 'ç');
MovieTitle := StringReplace(MovieTitle , 'â®', '');
MovieTitle := StringReplace(MovieTitle , '&', '&');
BeginPos := -1;
PickTreeExec(Address)
AnalyzeMoviePage(Address);
Item: string;
Comments: string;
Actors: string;
Directors: string;
Description: string;
Description := '';
// URL
// Titulo traducido
if LineNr <> -1 then
Item := TextBetween (Line, '//', '-');
Item := UpFirstLetterWord(Item);
Item := BorraComillas(Item);
Item := Trim(Item );
HTMLDecode(Item);
// categoria
SetField(fieldCategory, Trim ('Cine X'));
// Productor
LineNr := FindLine('>Productora</td>', Page, 0);
Item := copy(Page.Text, pos('>Productora</td>',Page.Text), length(Page.Text));
Item := TextBetween (Item, 'middle">', '</td>');
HTMLDecode(Item);
// sinopsis
LineNr := FindLine('id="det_subtitulo">', Page, 0);
Item := copy(Page.Text, pos('id="det_subtitulo">',Page.Text), length(Page.Text));
Item := TextBetween (Item, 'id="det_texto">', '<br></td> ');
HTMLDecode(Item);
// actores
LineNr := FindLine('">Interpretes</td>', Page, 0);
Item := copy(Page.Text, pos('">Interpretes</td>',Page.Text), length(Page.Text));
Item := TextBetween (Item, '"middle">', '...');
Item := StringReplace(Item ,#13#10, '');
Item := StringReplace(Item , ' ', '');
Item := StringReplace(Item , ', ',#13#10);
HTMLDecode(Item);
// director
LineNr := FindLine('Director</td>', Page, 0);
Item := copy(Page.Text, pos('Director</td>',Page.Text), length(Page.Text));
Item := TextBetween (Item, '"middle">', '</td>');
Item := StringReplace(Item , #13#10, ' ');
Item := StringReplace(Item , ' ', ' ');
HTMLDecode(Item);
// duración
LineNr := FindLine('Duració', Page, 0);
Item := copy(Page.Text, pos('Duració',Page.Text), length(Page.Text));
Item := TextBetween (Item, '">', 'Min.');
HTMLDecode(Item);
// trailer
LineNr := FindLine('trailer.php?video=', Page, 0);
Item := copy(Page.Text, pos('trailer.php?video=',Page.Text), length(Page.Text));
Item := TextBetween (Item, 'trailer.php?video=', '","trailer"');
HTMLDecode(Item);
SetField(fieldComments, Trim ('Trailer de la pelicula: '+Item));
// Caratula
LineNr := FindLine('<img src="imagenes/', Page, 0);
Item := TextBetween (Line, 'src="', '" width');
GetPicture ('http://www.maesen.com/sexshop/'+Item);
Input('Maesen', 'Buscar:', MovieName);
if(GetOption('Sin resultado') = 0) then Input('Maesen', 'Buscar:', MovieName);
AnalyzePage('http://www.google.es/search?num=100&hl=es&as_qdr=all&q=+%22' + UrlEncode(MovieName)+'%22+site%3Awww.maesen.com&btnG=B%C3%BAsqueda&meta=');
