[REL] [UPDATE] [ES] CaratulasDeCine
japg2000
Post by japg2000 »
Hello.
I've updated the script due to changes in the page that make the previous version not working anymore.
Authors=japg2000 (japg2000@terra.es)
Title=CaratulasDeCine
Description=Picture importation script for www.caratulasdecine.com
Site=www.caratulasdecine.com
Language=ES
Version=1.7
Requires=3.5.0
Comments=
program CaratulasdecineImport;
  Title: string;
  result := -1;
  if StartAt < 0 then
    StartAt := 0;
      result := i;
  result := S;
  while Pos(CR, result) = 1 do
function CadenaEntre(var S: string; StartTag: string; EndTag: string): string;
  InicioPos: Integer;
  InicioPos := Pos(StartTag, S);
  Delete(S, 1, InicioPos + Length(StartTag) - 1);
  InicioPos := Pos(EndTag, S);
  result := copy(S, 1, InicioPos - 1);
  Delete(S, 1, InicioPos + 1);
function PreparaTitulo(T: string): string;
  result := AnsiLowerCase(T);
  HTMLDecode(result);
  result := StringReplace(result, chr(146), '');
  result := StringReplace(result, chr(39), '');
  result := StringReplace(result, '´', '');
  result := StringReplace(result, '`', '');
  result := StringReplace(result, '"', '');
  result := StringReplace(result, '¿', '');
  result := StringReplace(result, '?', '');
  result := StringReplace(result, '¡', '');
  result := StringReplace(result, '!', '');
  result := StringReplace(result, '.', '');
  result := StringReplace(result, ',', '');
  result := StringReplace(result, ':', '');
  result := StringReplace(result, ';', '');
  result := StringReplace(result, '-', '');
  result := StringReplace(result, '/', '');
  result := StringReplace(result, '\', '');
  result := StringReplace(result, '_', '');
  result := StringReplace(result, 'á', 'a');
  result := StringReplace(result, 'é', 'e');
  result := StringReplace(result, 'í', 'i');
  result := StringReplace(result, 'ó', 'o');
  result := StringReplace(result, 'ú', 'u');
  result := StringReplace(result, 'ä', 'a');
  result := StringReplace(result, 'ë', 'e');
  result := StringReplace(result, 'ï', 'i');
  result := StringReplace(result, 'ö', 'o');
  result := StringReplace(result, 'ü', 'u');
  result := StringReplace(result, 'ñ', 'n');
function GetCaratulasDeCineDir(MovieTitle: string): string;
  PageOfLetter: Array of string;
  C: Char;
  Index: Integer;
  Setarraylength(PageOfLetter,36);
  PageOfLetter[0]:='0';  PageOfLetter[1]:='1';  PageOfLetter[2]:='2';  PageOfLetter[3]:='3';
  PageOfLetter[4]:='4';  PageOfLetter[5]:='5';  PageOfLetter[6]:='6';  PageOfLetter[7]:='7';
  PageOfLetter[8]:='8';  PageOfLetter[9]:='9';  PageOfLetter[10]:='a'; PageOfLetter[11]:='b';
  PageOfLetter[12]:='c'; PageOfLetter[13]:='d'; PageOfLetter[14]:='e'; PageOfLetter[15]:='f';
  PageOfLetter[16]:='g'; PageOfLetter[17]:='h'; PageOfLetter[18]:='i'; PageOfLetter[19]:='j';
  PageOfLetter[20]:='k'; PageOfLetter[21]:='l'; PageOfLetter[22]:='m'; PageOfLetter[23]:='n';
  PageOfLetter[24]:='o'; PageOfLetter[25]:='p'; PageOfLetter[26]:='q'; PageOfLetter[27]:='r';
  PageOfLetter[28]:='s'; PageOfLetter[29]:='t'; PageOfLetter[30]:='u'; PageOfLetter[31]:='v';
  PageOfLetter[32]:='w'; PageOfLetter[33]:='x'; PageOfLetter[34]:='y'; PageOfLetter[35]:='z';
  C := copy(MovieTitle, 1, 1);
  if (C >= '0') and (C <= '9') then
  	Index := Ord(C) - Ord('0');
  	Index := 10 + Ord(C) - Ord('a');
  result:='http://www.caratulasdecine.com/listado.php?inicial=' + PageOfLetter[Index];
procedure AnalyzePageCaratulasDeCine(PageDir: string);
  CaratulasdecinePage, MoviePage: TStringList;
  MovieDir, Line, LineTmp, TitleWeb, PageWeb: string;
  Encontrado, Salir, BeginPos, EndPos, LineNr, LineMov: Integer;
  CaratulasdecinePage := TStringList.Create;
  CaratulasdecinePage.Text := GetPage(PageDir);
  LineNr := FindLine('</big></big></big></big></big></big>', CaratulasdecinePage, 0);
  LineNr := LineNr + 2;
  Line := CaratulasdecinePage.GetString(LineNr);
  Line := EliminaInicio(Line, ' ');
  Salir := 0;
  Encontrado := 0;
  PickTreeAdd('Resultados de la búsqueda para "' + Title + '" (www.caratulasdecine.com):', '');
  while (Pos('<br>', Line) = 0) and (Pos('</td>', Line) = 0) and (LineNr < 20000) do
    if copy(Line, Length(Line), 1) <> ' ' then
      Line := Line + ' ';
    LineNr := LineNr + 1;
    LineTmp := CaratulasdecinePage.GetString(LineNr);
    LineTmp := EliminaInicio(LineTmp, ' ');
    Line := Line + LineTmp;
    if Pos('<a class="A" href="', Line) > 0 then
      MovieDir := 'http://www.caratulasdecine.com/' + CadenaEntre(Line, '<a class="A" href="', '"');
      TitleWeb := CadenaEntre(Line, '">', '<');
      LineTmp := PreparaTitulo(TitleWeb);
      if Pos(Title, LineTmp) > 0 then
        PageWeb := MovieDir;
        PickTreeAdd(TitleWeb, PageWeb);
        Encontrado := Encontrado + 1;
      MovieDir := '';
      Salir := 1;
  until Salir = 1;
  CaratulasdecinePage.Free;
  if (Encontrado > 1) then begin
     if PickTreeExec(PageWeb) then begin
        MoviePage := TStringList.Create;
        MoviePage.Text := GetPage(PageWeb);
        LineMov := FindLine('<td><img src="', MoviePage, 0);
        LineTmp := MoviePage.GetString(LineMov);
        LineTmp := CadenaEntre(LineTmp, '<td><img src="', '" ');
        PageWeb := 'http://www.caratulasdecine.com/' + LineTmp;
        MoviePage.Free;
        GetPicture(PageWeb);
  end else if (Encontrado = 1) then begin
     MoviePage.Free;
     ShowMessage('Titulo ' + Title + ' no encontrado en ' + PageDir)
  if CheckVersion(3,5,0) then
    Title := GetField(fieldTranslatedTitle);
    if Title = '' then Title := GetField(fieldOriginalTitle);
    Title := PreparaTitulo(Title);
    if Input('Importar de caratulasdecine.com', 'Por favor, introduce el titulo:', Title) then begin
      AnalyzePageCaratulasDeCine(GetCaratulasDeCineDir(Title));
    ShowMessage('Este script necesita una versión superior de Ant Movie Catalog (al menos la version 3.5.0)');
Greetings.
japg2000
Post by japg2000 »
Hello,
the page has changed again so here is a new working script.
Authors=japg2000 (japg2000@gmail.com)
Language=ES
Version=1.8
Requires=3.5.0
Comments=
  Title: string;
  result := -1;
  if StartAt < 0 then
    StartAt := 0;
      result := i;
  result := S;
  InicioPos: Integer;
  HTMLDecode(result);
function GetCaratulasDeCineDir(MovieTitle: string; SubPage: Integer): string;
  C: Char;
  Index: Integer;
  SubPage := SubPage*60;
  result:='http://www.caratulasdecine.com/listado.php?inicial=' + PageOfLetter[Index] + '&primero=' + IntToStr(SubPage);
procedure AnalyzePageCaratulasDeCine(Ttl: string);
  PageDir, MovieDir, Line, LineTmp, TitleWeb, PageWeb: string;
  SubPage, Encontrado, Salir, SalirTodo, BeginPos, EndPos, LineNr, LineMov: Integer;
  SubPage := 0;
  SalirTodo:= 0;
  Encontrado := 0;
  repeat begin
    PageDir := GetCaratulasDeCineDir(Ttl, SubPage);
    SubPage := SubPage + 1;
    Salir := 0;
        Line := Line + ' ';
    if Pos('>siguiente</a>', Line) = 0 then
      SalirTodo := 1;
        MovieDir := '';
        Salir := 1;
    until Salir = 1;
  end until SalirTodo = 1;
        MoviePage.Free;
     MoviePage.Free;
      AnalyzePageCaratulasDeCine(Title);
