Error
protathlitis
Error
Post by protathlitis »
When i run the latest imdb script (found in the temp folder) i get the error "Read timeout" right after the "chunk started". When i press ok i get another http 1.1 error i think. I get this error in the majority of the movies. I have the 3.5.1 beta/debug version.
Sorry, i made by mistake a new topic instead of posting my problem in the imdb topic. You may move it if you want, because i didn't find the way to do it.
This is maybe not only due to the script actually.
Can you try to go in the Preferences window, on Scripting page, and see if "keep connection" option is checked or not? Try to change its state, maybe it will solve the problem.
Else it looks more like some proxy server, firewall or something else that blocks the connection...
protathlitis
It was my avirus! When i disable it, the script import run perfect! I have the Kaspersky Anti-Virus. Any idea for that?
Anyway, thanks for your help.
I suppose that there is a firewall in Kaspersky then... You have to search in its options if somewhere you can define rules to let a particular program access to internet.
yeti
Post by yeti »
I've posted this last year:
viewtopic.php?p=19945#19945
HTH,
Andreas
protathlitis
thanks Yeti, i change the setting on the Kaspersky and the problem solved!
