special signs give no results
spotlight
Post by spotlight »
Hey Antp,
If you type Mr. & Mrs Smith it can't find any hits.
If you type Mr Mrs Smith, it do as well.
It looks that it do no accept special signs like: . & " ' ( § è ! ç à ) - ...ect.
Is that a bug in the program?
On the website database is it: Mr. & Mrs Smith
Well, from the screen capture I guess that your question is related to the "MovieMeter" script...
If you type "Mr. & Mrs Smith" in the search box on www.moviemeter.nl it does not give any result either.
When I type "Mr Mrs Smith" it works fine in both website and script.
spotlight
reply
Post by spotlight »
I see,
i think about this for future inserts.
Thanks for your answer.
