How limit the number of characters maximum in a text field?
RANICUAJO
Post by RANICUAJO »
In the print template that I use (create with "designer"), I would like to limit the number of characters that can appear in each text field.
Exists some form to do it with "script option" when the field is created? :hum:
Also I would like to know as a text can be put in vertical position :??:
Thanks :wow:
By vertical you mean rotated of 90/270°, or with letters like
T
E
X
T
in first case, you can chose the orientation of text blocks using a button of the toolbar. In second case it is not possible.
To limit the Length of a field, you can do the following:
Instead of having for example [Actors] in the text block, enter a new name, e.g. [shortActorsList]
Then check the "Script" option and enter the following in the bottom area:
  shortActorsList := Copy([Actors], 1, 50);
To keep 50 characters starting at the 1st one.
Of course it may cut in the middle of a name...
You can add "(...)" at the end:
  shortActorsList := Copy([Actors], 1, 22) + '(...)';
The report preview window of AMC may throw an error about a not found field when you refresh a template containing a script after having modified it, but it should work if you go to another template in the list then go back to your template.
RANICUAJO
Post by RANICUAJO »
antp wrote:Hi,
T
E
X
T
Hi
Finally i see the button :ha: I was thinking in the easy mode (rotate 90/270) but my eyes don´t see very well :badidea:
antp wrote: You can add "(...)" at the end:
Really you are in thel ine, but I have tried the 2 options (2ª is really better), but it use same "actors" data for all the films
(you will understand better in the image), and i have and error message when i try to print in a PDF "undefined symbol "actors"
Thanks for your help Antp :grinking:
I do not know why it does not work.
This script things often has a quite random behavior. Sometimes it works, sometimes not.
It is a ready-to-use component that I integrated in AMC, so I do not know what causes that. Someday I should find why such errors occurs.
RANICUAJO
Post by RANICUAJO »
I do not understand either so that it does not work, but don't worry too much antp.
Thanks again for your help and your patience :grinking:
Bye :wink:
RANICUAJO
Post by RANICUAJO »
Hi antp
I have a partial solution.
I have created a new variable in the “variable editor” with the following expression
The variable it initially stored in the group of "movie fields"
This is the result
The print report work properly all time,. but the problem now is that when I open designer again, non encounter the new variable that I have created with object to edit it :??:
Where is stored the new variables? :??:
Bye :grinking:
I didn't even know that it was possible to add variables like that :lol:
RANICUAJO
Post by RANICUAJO »
antp wrote:I didn't even know that it was possible to add variables like that :lol:
I hope that it can serve to you for something. New things are always discovered. I found it by chance, and knew that to put, thanks to the data that you gIve me. :D
I have a new question. :ha:
in a simple field of text (non variable for the moment :??: ...) for example “actors list” is possible to do that:
If “actors” lenght >0 then insert the text “actor list”
If “actors” lenght =0 then don't insert the text “actor lists”
When "actors" is the variable originated in AMC?
Thanks again
But if the text length is 0 there is nothing to insert, so the result will be the same, no ? :??:
RANICUAJO
Post by RANICUAJO »
I'm thinkin in the label before the AMC information.
Sorry for my bad english. It is so difficult to make understand me :ha: :ha: :ha:
I hope you understand the image.
Bye :grinking:
ok ;)
in the Script box of these text blocks, you can try to enter this:
  Visible := [Actors] <> '';
RANICUAJO
Post by RANICUAJO »
Script really works fine. :)
A million of thanks antp :grinking: :grinking: :grinking:
