[REL] [ENG] auto.imdb.com is my modified IMDB script
HappyTalk
Post by HappyTalk »
I saw the ongoing bizniz with imdb changing so I thought if I posted my modified script, that currently works fine for my uses (I don't use comments + some other fields myself so dunno if all work) it may solve some of the problems. However this was originally done in October 2006 so was based on the IMDB from then which as I understand it has undergone various major modifications itself. Maybe the maintainer of the current IMDb script may wish to merge some bits of my modded script (or not). It's got a different name so can be dropped in alongside original IMDB script
Main changes were :-
- To automate it so it can grab all entries with no user prompts. Set script options for imdb & amazon pic info as desired.
- Grabbing the large picture from amazon (that was broken in the IMDB script at the time I modded it)
- added option to ONLY use current URL (for updating stuff like ratings, choosing different length description etc)
- set const for url to former.imdb.com so works with new imdb
- Other minor issues I cannot now remember
The 2 files you need may be downloaded from here:-
http://antp.be/temp/scripts/auto.imdb.com.ifs &
http://antp.be/temp/scripts/AutoUtils.pas
Here they are in regular text format:-
auto.imdb.com.ifs
Authors=HappyTalk (Modified version of original script by Antoine Potten & KaraGarga)
Title=Auto.IMDB.com
Description=Import data & picture from IMDB (optional large image from Amazon.com)
Site=us.imdb.com
Language=EN
Version=2.05
Requires=3.5.0
Comments=Based on the script made for version 3.x by Antoine Potten, Danny Falkov, Kai Blankenhorn, lboregard, Ork, Trekkie, Youri Heijnen||Modified by HappyTalk to fix large amazon pic import, and a few other things
ImageKind=0|1|0=No image|1=Import from Amazon.com. Prompt with movie selector|2=Import from Amazon.com. No prompts, use first movie cover
BatchMode=0|0|0=Normal working mode, prompts user when needed|1=Does not display any window, takes the first movie found|2=Same as 1, but it uses the URL field if available to update movie information|3=Only updates using current URL field
PopularSearches=1|1|0=Do not use the popular searches page, directly show full search results|1=Show popular searches first, I'll click on "Find more" if needed (much faster)
ActorsLayout=0|2|0=Only actor names, separated by commas|1=Only actor names, separated by linebreaks|2=Actors names with character names between parenthesis separated by commas|3=Actors names with character names between parenthesis separated by linebreaks|4=Actor names like on IMDB page, with "...." and separated by linebreaks
MultipleValuesCountry=0|0|0=Only take first value for Country|1=Take full list, separated by commas|2=Take full list, separated by slashes
MultipleValuesCategory=1|0|0=Only take first value for Category|1=Take full list, separated by commas|2=Take full list, separated by slashes
MultipleValuesLanguages=0|0|0=Only take first value for Languages|1=Take full list, separated by commas|2=Take full list, separated by slashes
DescriptionSelection=2|1|0=Take the short summary, from main page (faster)|1=Show a list of available summaries|2=Take the longest summary|3=Take the shortest summary
GetTagline=0|0|0=Do not get tagline|1=Put it in Description field, before the summary|2=Put it in the Comment field, before the comments
Trivia=0|0|0=Do not import trivia|1=Import trivia to Description field, after the summary|2=Import trivia to Comments field, after the comments
AmazonReview=0|0|0=Do not get Amazon Review|1=Get Amazon Review
CommentType=2|0|0=Standard Type (Only one comment from main page)|1=Detailed Type (10 most useful comments from comments page)|2=No user comment
Awards=0|0|0=Do not import awards|1=Import awards to Description field, after the summary|2=Import awards to Comments field, after comments
program Auto_IMDB_com;
  StringUtils1, AutoUtils;
//  IMDB_URL = 'http://us.imdb.com';
  IMDB_URL = 'http://former.imdb.com';
  MovieURL: string;
  MovieNumber: string;
// ***** analyzes the results page that asks to select a movie from a list *****
  PageText: string;
  Value: string;
  PageText := GetPage(Address);
  if pos('<title>IMDb', PageText) = 0 then
    AnalyzeMoviePage(PageText)
        ShowMessage('No movie found for this search');
      Exit;
        Value := TextBefore(PageText, '<ol>', '<b>');
        if Value <> '' then
          HTMLRemoveTags(Value);
          HTMLDecode(Value);
          PickTreeAdd(Value, '');
        Value := TextBetween(PageText, '<ol>', '</ol>');
        PageText := RemainingText;
      until not AddMovieTitles(Value);
      Value := TextBefore(PageText, '"><b>more titles</b></a>', '<a href="');
      if Value <> '' then
        PickTreeMoreLink(IMDB_URL + Value);
        AnalyzeResultsPage(Address);
      Value := TextBetween(TextBetween(PageText, '<ol>', '</ol>'), '<li>', '</li>');
      if Value <> '' then
        AnalyzeResultsPage(TextBetween(Value, '<a href="', '">'));
// ***** adds the titles contained in <ol>'s items *****
  Value: string;
  Address: string;
  Result := False;
  Value := TextBetween(List, '<li>', '</li>');
  List := RemainingText;
  while Value <> '' do
    Address := TextBetween(Value, '<a href="', '">');
    HTMLDecode(Value);
    PickTreeAdd(Value, IMDB_URL + Address);
    Result := True;
// ***** analyzes the page containing movie information *****
procedure AnalyzeMoviePage(PageText: string);
  Value, Value2, Value3, FullValue, sMovieTitle: string;
  p: Integer;
  MovieNumber := TextBetween(PageText, '<input type="hidden" name="auto" value="legacy/title/tt', '/"><input');
  MovieURL := 'http://imdb.com/title/tt' + MovieNumber;
  // URL
  if CanSetField(fieldURL) then
    //if (GetField(fieldSource) = '') and (CanSetField(fieldSource)) then SetField(fieldSource, GetField(fieldURL)); /// now done in other routine after import
    SetField(fieldURL, MovieURL);
  // XXX Original Title & Year
// fieldOriginalTitle
  Value := TextBetween(PageText, '<title>', '</title>');
  Value2 := TextBefore(Value, ' (', '');
  Value := RemainingText;
  HTMLDecode(Value2);
  sMovieTitle := value2;
  if CanSetField(fieldOriginalTitle) then SetField(fieldOriginalTitle, sMovieTitle);
// fieldYear
  if Pos('/', Value) > 0 then
    Value2 := TextBefore(Value, '/', '')
    Value2 := TextBefore(Value, ')', '');
  if CanSetField(fieldYear) then SetField(fieldYear, Value2);
  // Rating
    Value := TextBetween(PageText, '/rating-stars/', '/rating-vote/');
    SetField(fieldRating, TextBetween(Value, '<b>', '/'));
  // Picture
  if CanSetPicture then
    case GetOption('ImageKind') of
      1:  ImportAmazonPicture(sMovieTitle, true);
      2:  ImportAmazonPicture(sMovieTitle, false);
  // Director
    Value := TextBetween(PageText, '<b class="blackcatheader">Directed by</b><br>', '<br>' + #13);
    Value := StringReplace(TextAfter(Value, '">'), '<br>', ', ');
    HTMLDecode(Value);
  // Actors
    Value := TextBetween(PageText, 'ast overview', '</div>');
    if Value = '' then
      Value := TextBetween(PageText, 'redited cast', '</div>');
    if Value = '' then
      Value := TextBetween(PageText, 'Cast:', '</table>');
    if Value = '' then
      Value := TextBetween(PageText, 'ast Summary:', '</table>');
    if Value <> '' then
      Value := Trim(TextAfter(Value, '</tr>'));
      FullValue := '';
      case GetOption('ActorsLayout') of
        0, 1:
          while Pos('<tr>', Value) > 0 do
            Value2 := TextBetween(Value, '<tr', '</tr>');
            if Pos('rest of cast', Value2) > 0 then
              Continue;
            if Pos('<a href="fullcredits">(more)</a>', Value2) > 0 then
            if FullValue <> '' then
            TextBefore(Value2, '</td>', '');
            Value2 := TextBetween(RemainingText, '/">', '</a>');
            if Value2 <> '' then
              FullValue := FullValue + Value2;
        0, 1:
            Value2 := TextBetween(Value, '<tr>', '</tr>');
              Continue;
            FullValue := FullValue + TextBefore(Value2, '</td>', '');
        2, 3:
              Continue;
               Value2 := TextBetween(RemainingText, 'e">', '</td>');
                FullValue := FullValue + ' (as ' + Value2 + ')';
        2, 3:
              Continue;
            Value2 := TextBetween(RemainingText, '<td valign="top">', '</td>');
        4:
            FullValue := TextBefore(Value, '</tr><tr><td colspan="2">', '');
            if FullValue = '' then
              FullValue := Value;
            FullValue := StringReplace(FullValue, ' <tr><td align="center" colspan="3"><small>rest of cast listed alphabetically:</small></td></tr> ', '');
            FullValue := StringReplace(FullValue, '</tr>', #13#10);
      HTMLRemoveTags(FullValue);
      HTMLDecode(FullValue);
        0, 2:
          FullValue := StringReplace(FullValue, #13#10, ', ');
//      SetField(fieldActors, FullValue);
      SetField(fieldActors, FixActors(FullValue)); //xxx Run through FixActors to leave just comma sep'd actors
  //Country
    SetField(fieldCountry, ImportList(PageText, GetOption('MultipleValuesCountry'), '/Countries/'));
  //Category only set for _M.ovies
    //value := GetField(fieldCategory); //xxx If blank or _M.ovie ensure _Movie is appended, else leave alone
    //if (value = '') or (pos('_M.ovie',value) > 0)  then
      SetField(fieldCategory, ImportList(PageText, GetOption('MultipleValuesCategory'), '/Genres/')); // + ',_M.ovie');
  // Language
  if CanSetField(fieldLanguages) then
    SetField(fieldLanguages, ImportList(PageText, GetOption('MultipleValuesLanguages'), '/Languages/'));
  // Description
  if CanSetField(fieldDescription) then
    Value := TextBetween(PageText, '<b class="ch">Plot Outline:</b>', '<br><br>');
    if Value = '' then
      Value := TextBetween(PageText, '<b class="ch">Plot Summary:</b>', '<br><br>');
    if Value <> '' then
      SetField(fieldDescription, ImportSummary(Value));
    // Amazon.com Description
    if (GetOption('AmazonReview') > 0) then
      Value := TextAfter(PageText, '<a href="amazon">');
      if Value <> '' then
        Value := GetField(fieldURL);
        PageText := GetPage(Value+'/amazon');
        Value := TextBetween(PageText, 'Amazon.com video review:', '<div align="center"> <!--');
        Value2 := TextBetween(PageText, '<title>', '</title>');
        Value := StringReplace(Value, #13#10, '');
        Value := StringReplace(Value, '  ', '');
        Value := StringReplace(Value, '<p>', #13#10+'');
        HTMLRemoveTags(Value2);
        Value2 := AnsiUpperCase(Value2);
        SetField(fieldDescription, GetField(fieldDescription) + #13#10 + #13#10 + Value2 + ': ' + Value);
  // Length
    Value := TextBetween(PageText, '<b class="ch">Runtime:</b>' + #13#10, ' ');
    if Value <> '' then
      if Pos(':', Value) > 0 then
        SetField(fieldLength, TextAfter(Value, ':'))
        SetField(fieldLength, Value);
  // Writer (Producer Field)
    Value := TextBetween(PageText, '<b class="blackcatheader">Writing credits</b>', '<br>' + #13#10 + '<br>');
    if Value <> '' then
      Value := StringReplace(Value, '(<a href="/wga">WGA</a>)', '');
      HTMLDecode(Value);
      Value := Trim(StringReplace(Value, '...,  (more)', ''));
      Value := Trim(StringReplace(Value, ',  (more)', ''));
      SetField(fieldProducer, Value)
  // AKA Name
    Value := TextBetween(PageText, '<b class="ch">Also Known As:</b><br>', '<br>' + #13#10 + '<b');
    if Value <> '' then
      Value := StringReplace(Value, ' <br>', ', ');
      HTMLDecode(Value);
      SetField(fieldTranslatedTitle, Value)
  // Comments
    if (GetOption('CommentType') = 1) then
      Value := TextAfter(PageText,'<a href="usercomments">');
      if Value <> '' then
        FullValue := GetPage(Value+'/usercomments');
        Value := TextBetween(FullValue, '<hr size="1" noshade="1">', '<hr size="1" noshade="1">');
        Value2 := TextBetween(FullValue, '<title>', '</title>');
        Value := StringReplace(Value, #13#10, ' ');
        Value := StringReplace(Value, '</b>, <small>', #13#10+'Date: ');
        Value := StringReplace(Value, '</small><br>', #13#10);
        Value := StringReplace(Value, '</b>', #13#10);
        Value := StringReplace(Value, '<br><br>', #13#10);
        Value := StringReplace(Value, '<p>', #13#10);
        Value := StringReplace(Value, 'Add another comment', '');
        Value := StringReplace(Value, 'Was the above comment useful to you?', #13#10+'___________'+#13#10);
        HTMLDecode(Value);
        HTMLDecode(Value2);
        Value := StringReplace(Value, ' Author:', 'Author:');
        SetField(fieldComments, Value2 + ':' + #13#10 + Value);
    if (GetOption('CommentType') = 0) then
      Value := TextAfter(PageText, '/comments">');
      if Value <> '' then
        Value := TextBetween(Value, '<p>', '</p>');
        HTMLDecode(Value);
        Value := Trim(Value);
        while Pos('  ', Value) > 0 do
        while Pos(#13#10, Value) = 1 do
          Delete(Value, 1, 2);
  // TagLine
  if GetOption('GetTagline') > 0 then
    Value := TextBetween(PageText, 'Tagline:</b>', #13);
    if Pos('<a', Value) > 0 then
      Value := TextBefore(Value, '<a', '');
    HTMLDecode(Value);
    if Value <> '' then
      if Copy(Value, 1, 1) <> '"' then
        Value := '"' + Value + '"';
      case GetOption('GetTagline') of
        1:
            if GetField(fieldDescription) <> '' then
              Value := Value + #13#10 + #13#10 + GetField(fieldDescription);
        2:
            if GetField(fieldComments) <> '' then
              Value := Value + #13#10 + #13#10 + GetField(fieldComments);
  // Trivia
  if GetOption('Trivia') > 0 then
    Value := TextAfter(PageText, '<a href="trivia">');
    if Value <> '' then
      sleep(50);
      FullValue := GetPage(Value+'/trivia');
      Value := TextBetween(FullValue, '<ul class="trivia">', '<div align="center"> <!--');
      Value := StringReplace(Value, '<li>', #13#10 + '- ');
      HTMLDecode(Value);
      HTMLDecode(Value2);
      case GetOption('Trivia') of
        1:
              Value := GetField(fieldDescription) + #13#10 + #13#10 + 'IMDB ' + Value2 + ': ' + Value
              Value :=  'IMDB ' + Value2 + ': ' + Value;
        2:
              Value := GetField(fieldComments) + #13#10 + #13#10 + 'IMDB ' + Value2 + ': ' + Value
  // Awards
  if (GetOption('Awards') > 0) then
    Value := TextAfter(PageText, '<a href="awards">');
    if Value <> '' then
      PageText := GetPage(Value+'/awards');
      Value2 := TextBetween(PageText, ' <h1>', '</h1>');
      Value := TextBetween(PageText, '<table cellspacing="2" cellpadding="2" border="1" width="95%">', '<!--');
      Value := StringReplace(Value, '<big>', '- ');
      Value := StringReplace(Value, '<tr><th>Year</th><th>Result</th><th>Award</th><th>Category/Recipient(s)</th></tr>', '');
      HTMLDecode(Value);
      HTMLDecode(Value2);
      Value2 := StringReplace(AnsiUpperCase(Value2), #13#10, '');
      Value := StringReplace(Value, ' '+#13#10, #13#10);
      while Pos(#13#10+#13#10, Value) > 0 do
        Value := StringReplace(Value, #13#10+#13#10, #13#10);
      FullValue:= Value2+': '+Value;
      case GetOption('Awards') of
        1:
              Value := GetField(fieldDescription) + #13#10 + #13#10 + Value2 + ': ' + Value
              Value := Value2 + ': ' + Value;
        2:
              Value := GetField(fieldComments) + #13#10 + #13#10 + Value2 + ': ' + Value
  if CanSetField(fieldChecked) then
    SetField(fieldChecked, ''); //xxx uncheck any items we set
// ***** Imports lists like Genre, Country, etc. depending of the selected option *****
function ImportList(PageText: string; MultipleValues: Integer; StartTag: string): string;
  Value, Value2: string;
  if MultipleValues = 0 then
    Value := TextBetween(PageText, StartTag, '</a>');
    Value2 := TextAfter(Value, '">');
    Value := TextBetween(PageText, StartTag, #13#10);
    Value2 := TextBefore(Value, ' <a href="/rg', '');
      Value := Value2;
    if MultipleValues = 1 then
      Value2 := StringReplace(Value2, ' / ', ', ');
  HTMLDecode(Value2);
  Result := Value2;
// ***** functions to import the different pictures kinds, depending of the option selected by user *****
function ImportSmallPicture(PageText: string): Boolean;
  Value: string;
  Result := False;
  Value := TextBetween(PageText, '<a name="poster"', '</a>');
  if Value <> '' then
    Value := TextBetween(Value, 'src="', '"');
    if Value <> '' then
      GetPicture(Value);
      Result := True;
function ImportLargePicture(Address: string): Boolean;
  Result := True;
  Value := GetPage(Address);
  if SearchForLargePicture(Value, 'Onesheet_text', False) then
    Exit;
  if SearchForLargePicture(Value, 'keyart01', True) then
    Exit;
  if SearchForLargePicture(Value, 'keyart02', True) then
    Exit;
  if SearchForLargePicture(Value, 'oster', True) then // poster, usposter, Poster
    Exit;
  if SearchForLargePicture(Value, 'pos01', True) then
    Exit;
  if SearchForLargePicture(Value, 'KeyArt', True) then
    Exit;
  if SearchForLargePicture(Value, 'heet', True) then // Sheet & Onesheet
    Exit;
  if SearchForLargePicture(Value, 'OneSheetv2', True) then
    Exit;
  if SearchForLargePicture(Value, 'artwork', True) then
    Exit;
  if SearchForLargePicture(Value, 'text', True) then
    Exit;
  Address := TextBetween(Value, 'There are ' + #13#10 + '<a href="', '">');
  if Address <> '' then
    Result := ImportLargePicture(IMDB_URL + Address)
    Result := False;
function SearchForLargePicture(PageText: string; Name: string; PartialName: Boolean): Boolean;
  Value: string;
  Result := False;
  if PartialName then
    Value := TextBefore(PageText, Name + '.jpg', '/');
    if Value = '' then
      Exit
      Name := Value + Name;
  Value := TextBefore(PageText, 'th-' + Name + '.jpg', 'src="');
  if Value <> '' then
    GetPicture(Value + Name + '.jpg');
    Result := True;
function ImportAmazonPicture(Title: String; ShowPicker: boolean): Boolean;
  PicUrl: string;
  result := false;
  PicUrl := GetAmazonPicUrl(Title, ShowPicker);
  if PicUrl <> '' then
    GetPicture(PicUrl); // use last value as will be same (for 2 part movies that use same image)
    result := true;
//Image from DVD Details Page
function ImportDvdDetailsPicture(PageText: string): Boolean;
  Value: string;
  Result := False;
  Value := TextAfter(PageText, '<a href="dvd">DVD details</a>');
  if Value <> '' then
    PageText := GetPage(Value+'/dvd');
    Value := TextBetween(TextBetween(PageText, 'internetmoviedat">', '></a>'), 'src="', '"');
    if Pos('amazon_logo', Value) = 0 then
      Value := StringReplace(Value, 'MZZZZZZZ', 'LZZZZZZZ');
      Value := StringReplace(Value, 'TZZZZZZZ', 'LZZZZZZZ');
      Value := StringReplace(Value, '.gif', '.jpg');
      GetPicture(Value);
      Result := True;
//Image from Merchandising Links (/sales) Page
function ImportMerchandisingPicture(PageText: string): Boolean;
  Value: string;
  Result := False;
  Value := TextAfter(PageText, '<a href="sales">');
  if Value <> '' then
    PageText := GetPage(Value+'/sales');
    Value := TextBetween(PageText, '<img src="http://images.', '"');
    if Value <> '' then
      GetPicture('http://images.'+Value);
      Result := True;
// ***** Gets summaries for the movie, based on the plot outline given in parameter (that contains the URL to more summaries) *****
function ImportSummary(PlotText: string): string;
  Address, Value, Value2, PageText, Longest, Shortest: string;
  Address := TextBetween(PlotText, '<a href="/rg/title-tease/plotsummary', '">(more)</a>');
  if (Address = '') or (GetOption('DescriptionSelection') = 0) then
    Result := Trim(TextBefore(PlotText, '<a href="/rg', ''));
    if Result = '' then
      Result := Trim(PlotText);
    HTMLRemoveTags(Result);
    HTMLDecode(Result);
    PageText := GetPage(IMDB_URL + '/rg/title-tease/plotsummary' + Address);
    PickListClear;
    Longest := '';
    Shortest := '';
    Value := TextBetween(PageText, '<p class="plotpar">', '</p>');
      HTMLDecode(Value);
      if Length(Value) > Length(Longest) then
        Longest := Value;
      if (Length(Value) < Length(Shortest)) or (Length(Shortest)=0) then
        Shortest := Value;
      PickListAdd(Trim(Value));
    if (GetOption('BatchMode') > 0) then
      Result := Shortest
    else if (GetOption('DescriptionSelection') = 2) then
      Result := Longest
    else if (GetOption('DescriptionSelection') = 3) then
      Result := Shortest
      if not PickListExec('Select a description for "' + GetField(fieldOriginalTitle) + '"', Result) then
        Result := '';
// ***** beginning of the program *****
  if CheckVersion(3,5,0) then
    MovieName := '';
    if GetOption('BatchMode') >= 2 then
      MovieName := GetField(fieldURL);
      if Pos('imdb.com', MovieName) = 0 then
        MovieName := '';
        if GetOption('BatchMode') = 3 then exit;
      if not Input('IMDB Import', 'Enter the title or the IMDB URL of the movie:', MovieName) then
        Exit;
      Sleep(500);
    if MovieName <> '' then
      if Pos('imdb.com', MovieName) > 0 then
        AnalyzeResultsPage(MovieName)
        MovieName := StringReplace(MovieName, '&', 'and');
        if (GetOption('BatchMode') > 0) or (GetOption('PopularSearches') = 1) then
          AnalyzeResultsPage(IMDB_URL + '/find?tt=1;q=' + UrlEncode(MovieName))
          AnalyzeResultsPage(IMDB_URL + '/find?more=tt;q=' + UrlEncode(MovieName));
AutoUtils.pas
unit AutoUtils;
AutoUtils by HappyTalk 2006.
Unit to add string, soundex and other functions to ANT
scripts. You may use unit in your scripts.
Please do not modify this original file, make a newly
named one. you can redistribute it and/or modify it under
Version = 2007.03.22
Currently used by
Auto.TV.Com
Auto.IMDB.Com
Auto.Tools scripts
const AutoUtils_Version = '2007.03.22';
// MATHS FUNCTIONS
// rets min of 2 values
function Min(X, Y: Integer): Integer;
  if X < Y then Min := X else Min := Y;
// rets max of 2 values
function Max(X, Y: Integer): Integer;
  if X > Y then Max := X else Max := Y;
// STRING FUNCTIONS
Function stringReverse(S : String): String;
Var
   i : Integer;
Begin
   Result := '';
   For i := Length(S) DownTo 1 Do
   Begin
     Result := Result + Copy(S,i,1) ;
   End;
End;
//finds pos of last sFind in sStr
Function revpos(sFind, sStr: string; p: Integer) : Integer;
p2: Integer;
  result := 0;
  if Length(Sstr) >= p then
    //p2 := pos(sFind, copy(sStr, p, length(sStr)- p + 1)) + p - 1;
    p2 := pos(sFind, StrMid(sStr, p, 0)) + p - 1;
    if p2 >= p then result := p2
// returns the pos of nth instance of sFind found in sStr going from reverse of string to start
Function nposrev(sFind, sStr: string; n: Integer) : Integer;
sFindRev, sStrRev: string;
p: Integer;
  sFindRev := stringReverse(sFind);
  sStrRev := stringReverse(sStr);
  p := npos(sFindRev, sStrRev, n);
  if p > 0 then
    result := Length(sStr) - p - Length(sFind) + 2
    result := 0;
// returns pos of sFind in sStr from position p in str
Function ppos(sFind, sStr: string; p: Integer) : Integer;
p2: Integer;
  result := 0;
// returns the pos of nth instance of sFind found in sStr or 0 if none.
Function npos(sFind, sStr: string; n: Integer) : Integer;
p: Integer;
  result := 0;
  p := 0;
    p := ppos(sFind, sStr, p+1);
    n := n - 1;
  until (p = 0) or (n = 0);
  result := p;
// gets the right hand string AFTER nth instance of sFind in sStr,
// if bReverse nth instance is nth from end working backwards
Function nposRight(sFind, sStr: string; n: Integer; bReverse: boolean) : string;
p: integer;
  result := '';
  if bReverse then
    p := nposrev(sFind, sStr, n) + Length(sFind) // set to pos AFTER nth occurrence
    p := npos(sFind, sStr, n) + Length(sFind); // set to pos AFTER nth occurrence
  if (p > Length(sFind)) and (p <= Length (sStr)) then
    result := StrMid(sStr, p, 0);
// gets the left hand string BEFORE nth instance of sFind in sStr
Function nposLeft(sFind, sStr: string; n: Integer; bReverse: boolean) : string;
p: integer;
  result := '';
  if bReverse then
    p := nposrev(sFind, sStr, n) - 1 // set to pos BEFORE nth occurrence
    p := npos(sFind, sStr, n) - 1; // set to pos BEFORE nth occurrence
  if (p > 0) then
    result := StrLeft(sStr, p);
Function StrLeft(str: string; len: Integer) : string;
  result := copy(str,1,len);
Function StrRight(str: string; len: Integer) : string;
  result := copy(str,Max(1,length(str)-len+1), len);
// rets len chars from position p or rest if len=0
Function StrMid(str: string; p, len: Integer) : string;
  if len = 0 then len := length(str)- p + 1;
  result := copy(str,p,len);
// replaces all occurences of sFind with sReplace in sStr from after n'th instance of sFind
function nposReplaceString(sFind, sReplace: string; sStr: string; n:Integer): string;
  p: Integer;
  p := npos(sFind, sStr, n) + 1;
  if p > 1 then
    sStr := posReplaceString(sFind, '', sReplace, sStr, p);
  result := sStr;
// replaces all occurences of text between sFindBeg & sFindEnd with sReplace in sStr from position FBeg onwards
// sFindEnd can be '' to only replace sFindBeg's not range
// sReplace can be '' to just erase each occurence
function posReplaceString(sFindBeg, sFindEnd, sReplace: string; sStr: string; FBeg: Integer): string;
  FEnd: Integer;
  if FBeg < 1 then FBeg := 1;
  while (true) do
    FBeg := ppos(sFindBeg, sStr, FBeg);
    if FBeg = 0 then break;
    if sFindEnd <> '' then
      FEnd := ppos(sFindEnd, sStr, FBeg+1);
      if FEnd = 0 then break;
      FEnd := FEnd + Length(sFindEnd);
      FEnd := FBeg + Length(sFindBeg);
    delete(sStr, FBeg, FEnd-FBeg);
    if sReplace <> '' then insert(sReplace, sStr, FBeg);
    FBeg := FBeg + Length(sReplace);
    if FBeg > Length(sStr) then Break;
  result := sStr;
// Removes all space from start and end and ensures there is no more than SpCnt consecutive space inside string
// also Strips HTML out if required
Function StripSpace(s: string; SpCnt: Integer; StripHTML: Boolean) : string;
i, cnt: Integer;
s2, ch: string;
  s2 := '';
  s := Trim(s);
  For i := 1 To Length(s) do
    ch := copy(s, i, 1);
    if (ch = ' ') then
      if (cnt < SpCnt) then
        s2 := s2 + ch;
        cnt := cnt + 1;
      s2 := s2 + ch;
      cnt := 0;
  if (StripHTML) and (Length(s2) > 0)  then
    HTMLRemoveTags(s2);
    HTMLDecode(s2);
  result := s2;
// ConvertAlphaSpace: converts certain punc chars to space(only allows 1 consecitive space) + removes numbers & rets rest as lower case
Function ConvertAlphaSpace(s: string) : string;
s2, ch: string;
    s := AnsiLowerCase(s);
    s2 := '';
        if (ch >= 'a') and (ch <= 'z') then
          s2 := s2 + ch
          case ch of
            ' ', '-', ':', '*', '?', '"', '<', '>', '.', '_', '\', '/', '|' : If StrRight(s2, 1) <> ' ' Then s2 := s2 + ' ';
    result := Trim(s2);
// ConvertAlpha: removes from a string all non alpha chars (inc spaces) and rets rest as lower case
Function ConvertAlpha(s: string) : string;
s2, ch: string;
    s2 := '';
        s2 := s2 + ch;
    result := s2;
// ConvertAlphaNum: removes from a string all non alphanum chars (inc spaces) and rets rest as lower case
s2, ch: string;
    s2 := '';
      if ((ch >= 'a') and (ch <= 'z')) or ((ch >= '0') and (ch <= '9')) then
        s2 := s2 + ch;
    result := s2;
// LOCATE TEXT FUNCTIONS
// accumulates all lines between those containing FindBeg & FindEnd strings (inclusive) offset by OffBeg & OffEnd
// BegFind can = EndFind to get same line if BegOff=0
function PageTextBetween(BegFind: string; BegOff: Integer; EndFind: string; EndOff: Integer; Page: TStringList; LineNr: Integer; StripHTML: Boolean): string;
BegPos, EndPos, i: Integer;
  result := '';
  if BegFind = '' then
    BegPos := LineNr // if no beg string go from current pos
    BegPos := FindLine(BegFind, Page, LineNr);// + BegOff;
  if BegPos > -1 then
    if EndFind = '' then
      EndPos := BegPos
      EndPos := FindLine(EndFind, Page, BegPos);
    if EndPos > -1 then
      BegPos := BegPos + BegOff;
      EndPos := EndPos + EndOff;
      for i := BegPos to EndPos do
        Line := Line + Page.GetString(i);
      Line := Trim(Line);
      if StripHTML then
        HTMLRemoveTags(Line);
        HTMLDecode(Line);
      result := Line;
// rets text between BegFind & EndFind use BegOff & EndOff to reposition
function LineTextBetween(BegFind: string; BegOff: Integer; EndFind: string; EndOff: Integer; Line: string; StripHTML: Boolean): string;
  result := '';
  BegPos := pos(BegFind, Line);
  if BegPos = -1 then exit;
  EndPos := ppos(EndFind, Line, BegPos+1);
  if EndPos = -1 then exit;
  BegPos := BegPos + Length(BegFind) + BegOff; //Beg = 1st char after BegFind
  EndPos := EndPos + EndOff; //End = 1st Char off EndFind
  if (BegPos <= EndPos) and (BegPos > 0) and (EndPos < Length(Line)) then
    Line := copy(Line, BegPos, EndPos-BegPos);
    if StripHTML then
      HTMLDecode(Line);
    result := Line;
  i, Cnt: Integer;
  result := -1;
  if StartAt < 0 then
    StartAt := 0;
  Cnt := List.Count-1;
  for i := StartAt to Cnt do
      result := i;
function FindLineNoCase(Pattern: string; List: TStringList; StartAt: Integer): Integer;
  result := -1;
  Pattern :=  AnsiLowerCase(Pattern);
  if StartAt < 0 then
    StartAt := 0;
    if Pos(Pattern, AnsiLowerCase(List.GetString(i))) <> 0 then
      result := i;
function FindLineAlpha(Pattern: string; List: TStringList; StartAt: Integer): Integer;
  result := -1;
  Pattern :=  ConvertAlpha(Pattern);
  if StartAt < 0 then
    StartAt := 0;
    if Pos(Pattern, ConvertAlpha(List.GetString(i))) <> 0 then
      result := i;
// do fuzzy search
function FindLineSoundEx(Pattern: string; List: TStringList; StartAt: Integer): Integer;
  result := -1;
  Pattern :=  ConvertSoundEx(Pattern);
  if StartAt < 0 then
    StartAt := 0;
    if SoundExComp(Pattern,List.GetString(i)) then
      result := i;
// SOUNDEX FUNCTIONS
Function ConvertSoundEx(sSent: string) : string;
Pos1,Pos2,SLen: Integer;
s, wrd: string;
    sSent := ConvertAlphaSpace(sSent);
    //sSent = ValidateChars(sSent) 'replace dodgy chars with spaces
    SLen := Length(sSent);
    Pos1 := 1;
    s := '';
    Repeat
        Pos2 := ppos( ' ', sSent,Pos1); //look for rest of str
        If Pos2 = 0 Then Pos2 := SLen + 1;
        wrd := copy(sSent, Pos1, Pos2 - Pos1);
        s := s + SoundEx(wrd);
        Pos1 := Pos2 + 1;
    Until Pos1 > SLen;
    result := s;
//takes 2 soundex strings looks for soundex string(s) sStr2 in sStr1. does as 4 char comps
Function SoundExIn(sFind, sStr: string) : Boolean;
var SLen, i, MatchCnt: Integer;
    SLen := Length(sFind) DIV 4;
    MatchCnt := 0;
    for i := 0 to SLen-1 do
        if (pos(copy(sFind, i * 4 + 1, 4), sStr) > 0) Then MatchCnt := MatchCnt + 1;
    result := ((MatchCnt * 100) DIV SLen) >= 60; //greater than 75% match => match
End;
//takes 2 normal strings and soundex converts. Then compares if str2 is in str1
Function SoundExComp(sFind, sStr : string) : Boolean;
  r: boolean;
    r := SoundExIn(ConvertSoundEx(sFind), ConvertSoundEx(sStr));
    result := r
End;
//converts a string into soundex. 4 chars per word
Function SoundEx(sWord: String) : String;
var Num, sChar, sLastCode: string;
    lWordLength, i: Integer;
    sWord := AnsiUpperCase(sWord);
    Num := copy(sWord, 1, 1); // Get the first letter
    sLastCode := GetSoundCodeNumber(Num);
    lWordLength := Length(sWord);
    // Create the code starting at the second letter.
    for i := 2 To lWordLength do
        sChar := GetSoundCodeNumber(copy(sWord, i, 1));
        // If two letters that are the same are next to each other only count one of them
        if (Length(sChar) > 0) And (sLastCode <> sChar) Then
          Num := Num + sChar;
          sLastCode := sChar;
    result := copy(Num + '    ', 1, 4); // Make sure code is exactly 4 chars
//The letters A,E,I,O,U,Y,H,W and other characters are not coded.
function GetSoundCodeNumber(sChar: string) : String;
  SC: string;
  SC := '';
// comma seperating this case statement = memory leaks???, hence done like this
  Case sChar of
    'B' : SC := '1';
    'F' : SC := '1';
    'P' : SC := '1';
    'V' : SC := '1';
    'C' : SC := '2';
    'G' : SC := '2';
    'J' : SC := '2';
    'K' : SC := '2';
    'Q' : SC := '2';
    'S' : SC := '2';
    'X' : SC := '2';
    'Z' : SC := '2';
    'D' : SC := '3';
    'T' : SC := '3';
    'L' : SC := '4';
    'N' : SC := '5';
    'M' : SC := '5';
    'R' : SC := '6';
  result := SC;
// FIELD FUNCTIONS
// removes dots after 4th dot
function FixTitles(sStr: string): string;
  result := '';
  if sStr = '' then exit;
  result := nposReplaceString('.', ' ', sStr, 4); // replace '.' with ' ' after 4th '.' change the 4 to ? as required
/// IMDB info has 'actorname (as partname)' this changes that to 'actor1,actor2,actor3'
function FixActors(sStr: string): string;
  result := '';
  sStr := posReplaceString(' (', '), ',',', sStr, 1); // replace ' (.....), '
  sStr := posReplaceString(' (', ')','', sStr, 1); // replace '.' with ' ' after 4th '.'
  sStr := posReplaceString('(', '','', sStr, 1); // erase any remaining '('
  sStr := posReplaceString(')', '','', sStr, 1); // erase any remaining ')'
  // sStr := posReplaceString(', ', '',',', sStr, 1); // remove spaces between ,'s
  result :=  sStr;
// OTHER FUNCTIONS
// rets url for large amazon pic given title. If ShowPicker = true will prompt with choices (if any)
function GetAmazonPicUrl(Title: String; ShowPicker: boolean) : String;
  LineNr, MovieCnt: Integer;
  Line, Address, Match: string;
  result := '';
  MovieCnt := 0;
  Address := 'http://www.amazon.com/s/ref=nb_ss_gw/103-7540265-9891830?url=search-alias%3Ddvd&field-keywords=' + StringReplace(UrlEncode(Title),'+', '%20');
  PickTreeAdd('Amazon matches for "' + Title + '" (' + GetField(fieldSource) + ')', '');
  LineNr := -1;
    LineNr := FindLine('<span class="srTitle">', Page, LineNr + 1);
    if LineNr < 0 then Break;
    Address := LineTextBetween('"http', -4, '">', 0, Line, False);
    if (Line <> '') and (Address <> '') then
      PickTreeAdd(Line, Address);
      if MovieCnt = 0 then Match := Address;
      MovieCnt := MovieCnt + 1;
  until (false);// or (LineNr > EndLine) or ((AutoFlag >= 3) and (SeCnt > 0));
  if MovieCnt <> 0 then //if no movies to select from may be it has gone straight to only choice so carry on
    if ShowPicker then
      if PickTreeExec(Address) = false then exit; //user select from all episodes
      Address := Match; //set to 1st match
    Page.Text := GetPage(Address); // get main movie page
// main movie page
  Line := PageTextBetween('registerImage("original_image"', 0, '', 0, Page, 0, False); //get the line
  Address := LineTextBetween('<a href="+''"''+"', 0, '"+''"''+" target="', 0, Line, False);
  if Address = '' then exit;
// movie large image page
  Line := PageTextBetween('imagePlaceHolder', 1, '', 1, Page, 0, False); //get the line after the 'imageplaceholder' one
  Address := LineTextBetween('<img src="', 0, '.jpg"', 4, Line, False);
  result := Address;
End;
// END
Re: [REL] [ENG] Auto.IMDB.Com is my modified IMDB script
HappyTalk wrote:Maybe the maintainer of the current IMDb script may wish to merge some bits of my modded script (or not).
It is mostly me that maintain the IMDB script, I am rewriting it (I should try to find time to finish it).
Maybe I will check what changes you made to include them. Or I can leave the script as a separated one, as you suggested.
austrian_dude
Post by austrian_dude »
that was exactly what i was looking for, happytalk.
thank you very much for this script.
í´m not into scripting so i cant imagine how much work this is.
two thumbs up!
i dont use comments either, but i use the field for the trivia import, and it works just fine!!
there is just one question about the picture import from amazon (which was also a great improvement):
as you may noticed i am from austria, and here in austria we got the same dvd covers as in germany, and those are quite different to the us dvd covers.
so my question is: will it work if i change just the link from the us-amazon site to the german-amazon site ?
thx again,
austria_dude
p.s.: i know my english (writing) could be a lot better.
..........i´m trying :P
HappyTalk
Post by HappyTalk »
I reckon your English is better than 70% of English people's, so no apology required.
OK well only way to know is to try it....
Well assuming 'Wie ein wilder Stier' is the German version of Raging Bull then it would appear to work fine.
All you need to do is edit the AutoUtils.pas file and change the 'amazon.com' reference to 'amazon.de' on line 584 leaving the rest of the line intact.
You can set to amazon.co.uk or others. I will update the script some time to add different countries as a script option.
BTW don't forget if you set the option so you get the list of picture choices you can press view page to see what the cover will be before you get it, so can easily choose the one you like most. The page will only show the small image, though script only downloads the larger ones. If you want small pics run a batch through photoshop (I currently do this to crop off the white space that amazon insists on surrounding their covers with)
cheers
austrian_dude
hey HappyTalk, do you have an idea to make your script work again ?
i have the "no movie found" problem as discussed on the forum, but i dont wanna change to a new imdb script without your modifications.
