Slightly modified DVDEmpire script based off of 2.0.3bugfix
murkyl
Post by murkyl »
I've copied and pasted the code below. What I've changed is the addition of Subtitle languages, the Languages which used to hold the audio types has been moved to Audio Format, and Languages now have the correct Audio languages available for the title. This is my first attempt at a script modification and posting here so if you have any issues please let me know and I'll try to fix them.
// DVDEmpire.com Script Version 2.0.3 bugfixed picturedownload (20070106/bad4u)
program From_dvdempire2;
  MovieName2: string;
  result := -1;
  if StartAt < 0 then
    StartAt := 0;
      result := i;
function GetValues(Line : String; UseCommaDelimiter : Boolean): String;
    Value     : String;
    StartPos  : Integer;
    EndPos    : Integer;
    Delimiter : String;
  Result := '';
  Line   := StringReplace(Line, '•', '');
  if (UseCommaDelimiter) then
    Delimiter := ','
    Delimiter := #13 + #10;
  while(true) do
    StartPos := Pos('">', Line) + 2;
    EndPos   := Pos('</a>', Line);
    Value    := Copy(Line, StartPos, EndPos - StartPos);
    Line     := Copy(Line, EndPos + 1, Length(Line) - EndPos);
    if (EndPos < StartPos) then
      break;
    Value := Trim(Value);
    HTMLDecode(Value);
    HTMLRemoveTags(Value);
    if (Length(Result) > 0) then
      Result := Result + Delimiter;
    Result := Result + Value;
procedure GetInfo(Page: TStringList; ItemID: String);
var Line, Value, Text, AudioFormat, Subtitles, Search, Search2 : String;
    LineNr, StartPos, EndPos, LineNrEnd, i, y : Integer;
    LineCR: Boolean;
  //originální název
  LineNr := FindLine('<title>DVD Empire - Item -', Page, 0);
  if LineNr >-1 then begin
    StartPos := Pos('DVD Empire - Item -',Line)+5;
    Value := Copy(Line, StartPos+15,Length(Line));
    HTMLDecode(Value);
  // URL
  SetField(fieldURL,'http://www.dvdempire.com/Exec/v4_item.asp?item_id=' + ItemID);
  //Rating
  LineNr := FindLine('<b>Rating:</b>', Page, 0);
  if LineNr > -1 then
    StartPos := Pos('<b>Rating:</b>',Line) + Length('<b>Rating:</b>');
    Line  := copy(Line, StartPos, Length(Line) - StartPos);
    Value := trim( copy(Line, 1, pos('<br />', Line) - 1) );
    SetField(fieldRating, Value);
  // Year
  LineNr := FindLine('<b>Production Year:</b>', Page, 0);
  if LineNr > -1 then
    StartPos := Pos('<b>Production Year:</b>', Line) + Length('<b>Production Year:</b>');
    Line := Copy(Line, StartPos, Length(Line) - StartPos);
    EndPos   := Pos(' ',Line);
    Value := Trim( Copy(Line, 1, EndPos - 1) );
    SetField(fieldYear, Value);
  // Runtime
  LineNr := FindLine('<b>Length:</b>', Page, 0);
    StartPos := Pos('<b>Length:</b>', Line) + Length('<b>Length:</b>');
    EndPos   := Pos('mins',Line);
    SetField(fieldLength, trim(Value));
  // Director
  LineNr := FindLine('<b>Directors:</b>', Page, 0);
  if LineNr > -1 then
    StartPos := Pos('<b>Directors:</b>', Line) + Length('<b>Directors:</b>');;
    Line   := Copy(Line, StartPos, Length(Line) - StartPos - 1);
    EndPos := Pos('</td>', Line);
    Line   := Copy(Line, 1, EndPos - 1);
    Value  := GetValues(Line, true);
  // Producer
  LineNr := FindLine('<b>Producers:</b>', Page, 0);
  if LineNr > -1 then
    StartPos := Pos('<b>Producers:</b>', Line) + Length('<b>Producers:</b>');
  // Actors
  LineNr := FindLine('<b>Actors:</b>', Page, 0);
  if LineNr > -1 then
    StartPos := Pos('<b>Actors:</b>', Line) + Length('<b>Actors:</b>');;
    Value  := GetValues(Line, false);
    SetField(fieldActors, Value);
  // Picture
  LineNr := FindLine('http://images.dvdempire.com/gen/movies/', Page, 0);
  if LineNr > -1 then
     Line := 'http://images.dvdempire.com/gen/movies/' + ItemID + 'h.jpg';
     GetPicture(Line);
  LineNr := FindLine('http://images2.dvdempire.com/gen/movies/', Page, 0);
  if LineNr > -1 then
     Line := 'http://images2.dvdempire.com/gen/movies/' + ItemID + 'h.jpg';
     GetPicture(Line);
  // AudioFormat
  LineNr := FindLine('PCM Stereo', Page, 0);
  if LineNr > -1 then
    If Length(AudioFormat)<>0 then AudioFormat := AudioFormat+', ';
    AudioFormat := AudioFormat+'PCM Stereo';
    SetField(fieldAudioFormat, AudioFormat);
  LineNr := FindLine('Dolby Digital Stereo', Page, 0);
  if LineNr > -1 then
    AudioFormat := AudioFormat+'Dolby Digital Stereo';
  LineNr := FindLine('Dolby Digital 5.0', Page, 0);
  if LineNr > -1 then
    AudioFormat := AudioFormat+'Dolby Digital 5.0';
  LineNr := FindLine('Dolby Digital 5.1', Page, 0);
  if LineNr > -1 then
    AudioFormat := AudioFormat+'Dolby Digital 5.1';
  LineNr := FindLine('Dolby Digital Surround', Page, 0);
  if LineNr > -1 then
    AudioFormat := AudioFormat+'Dolby Digital Surround';
  LineNr := FindLine('DTS Stereo', Page, 0);
  if LineNr > -1 then
    AudioFormat := AudioFormat+'DTS Stereo';
  LineNr := FindLine('DTS Surround', Page, 0);
  if LineNr > -1 then
    AudioFormat := AudioFormat+'DTS Surround';
  LineNr := FindLine('DTS 5.1', Page, 0);
  if LineNr > -1 then
    AudioFormat := AudioFormat+'DTS 5.1';
  // Subtitles
  Search := '<b>Subtitles:</b>';
  LineNr := FindLine(Search, Page, 0);
  if LineNr > -1 then
    StartPos := Pos(Search, Line) + Length(Search);
    EndPos := Length(Line) - StartPos + 1;
    Value  := Copy(Line, StartPos, EndPos);
    SetField(fieldSubtitles, trim(Value));
  // Genres
  Search := '<b>Genre</b>:';
  if LineNr > -1 then
    SetField(fieldCategory, trim(Value));
  // Audio languages extracted from the audio tracks
  Search := '<b>Audio:</b>';
  Search2 := '<b>Subtitles:</b>';
  LineNrEnd := FindLine(Search2, Page, 0);
  AudioFormat := '';
  if LineNr > -1 then if LineNrEnd > -1 then
    for i := LineNr to LineNrEnd - 1 do
      Line := Page.GetString(i);
      if i = LineNr then
        Value  := Copy(Line, 0, Length(Line));
      EndPos := Pos(':', Value) - 1;
      Line := Copy(Value, 1, 1);
      Value := Copy(Value, 2, EndPos - 1);
      Value := LowerCase(Value);
      Line := Line + Value;
      AudioFormat := AudioFormat+trim(Line);
    SetField(fieldLanguages, AudioFormat);
  // Description
  LineNr := FindLine('<td width="100%" valign="top" class="fontsmall3">', Page, 0) + 1;
  LineNrEnd := FindLine('</td>', Page, LineNR) - 1;
  if LineNr > -1 then
    for i := LineNR to LineNrEnd do begin
      LineCR:=false;
      Value := Page.GetString(i);
      If Pos('<br><br>', Value) <> 0 then LineCR:=true;
      Value:=StringReplace(Value, '>i<', '> <');
      HTMLDecode(Value);
      for y := 1 to Length(Value) do begin
         If Ord(Copy(Value, y, 1))=9 then begin
            Value:=Copy(Value, 1, y-1)+' '+Copy(Value, y+1, Length(Value));
      Text:=Text+Value+Chr(13)+Chr(10);
      If LineCR=true then Text:=Text+Chr(13)+Chr(10);
    SetField(fieldDescription,Copy(Text, 1, Length(Text)-4));
  LineNr, StartPos, EndPos, L, EndPos2: Integer;
  Line, TempValue: string;
  ItemID, MovieAddress, MovieTitle : string;
  AddItem : Boolean;
  if LineNr >-1 then
    LineNr := FindLine('javascript:itemHelp(', Page, 0);
    Line := Trim(Page.GetString(LineNr));
    // parameters are separated by ', '
    StartPos := pos(''', ''', Line) + 4; // move past the delimiter
    Line := copy(Line, StartPos, length(Line) - StartPos + 1); // skip the starting quotes
    ItemID := copy(Line, 0, pos(''', ''', Line) - 1);
    GetInfo(Page,ItemID);
    LineNr := FindLine('</strong> Matches Found', Page, 0);
    if LineNr >-1 then
      StartPos := pos('<strong>', Line) + Length('<strong>');
      L := StrToInt('0'+ Copy(Line, StartPos, pos('</strong>', Line) - StartPos),1);
      PickTreeAdd(IntToStr(L)+' Matches found', '');
      If L>0 Then
        // Find Films
        LineNr := FindLine('&searchID=', Page, LineNr + 1);
          Line := Trim( Page.GetString(LineNr) );
              // find the item id
              EndPos   := Pos('&searchID=', Line);
              StartPos := EndPos;
              if (EndPos < 1) then
                break;
                TempValue := Copy(Line, StartPos, 1);
                if (TempValue = '=') then
                  break;
                StartPos := StartPos - 1;
              until(StartPos < 1);
              StartPos := StartPos + 1;
              ItemID := Copy(Line, StartPos, EndPos - StartPos);
              MovieAddress := 'http://www.dvdempire.com/Exec/v4_item.asp?item_id=' + ItemID;
              // discard the stuff we've already processed
              EndPos := EndPos + Length('&searchID=');
              Line   := Copy(Line, EndPos, Length(Line) - EndPos - 1);
              // find the movie name
              StartPos := Pos('''>', Line) + 2;
              MovieTitle := Copy(Line, 1, EndPos - 1);
              // add it to the tree
              HTMLDecode(Movietitle);
              HTMLRemoveTags(MovieTitle);
              // exclusion list -- these are false positives, not really titles
              AddItem := true;
              if (MovieTitle = 'Only Used Available') then
                AddItem := false;
              if (AddItem) then
          until (LineNr <1 );
      ItemID :=copy(Address, 51, 8);
  //DisplayResults;
// Begin program
  if CheckVersion(3,5,0) then
    PickListClear;
    if MovieName = '' then MovieName := GetField(fieldTranslatedTitle);
    if Input('Import from www.dvdempire.com (Modified)', 'Enter the title of the movie:', MovieName) then begin
        MovieName2:=MovieName;
        MovieName:=StringReplace(MovieName, '’', Chr(39));
        MovieName:=AnsiLowerCase(MovieName);
        MovieName:=AnsiUpFirstLetter(MovieName);
        if pos('The ', MovieName)=1 then MovieName:=StringReplace(MovieName, 'The ', '');
        // the &pp=5 makes sure we display all results in one page!
        AnalyzePage('http://www.dvdempire.com/Exec/v5_search_item.asp?string='+UrlEncode(MovieName)+'&pp=5');
I added "code" tags to make the text more readable, but your script is missing the "header" part. You should open the script in a text editor (notepad, ...) to copy whole content.
