[REL] [UPDATE] [ES] Culturalia+IMDB v1.6
folgui
Post by folgui »
¡Hi!
[EN] A few days ago, IMDB made some changes on their web, so rating/length were not imported correctly in this script. Fixed!
[ES] Hace unos días, IMDB ha hecho unos cambios en su página, lo cual impedía que se importase correctamente la valoración/duración. ¡Corregido!
Regards, folgui.
Authors=David Arenillas, Antoine Potten and J.M. Folgueira
Title=Culturalia(+IMDB)
Description=Movie importation script for Culturalia and IMDB
Site=http://www.culturalianet.com
Language=ES
Version=1.6 (04 Mar 2007)
Requires=3.5.0
Comments=Several updates made by: folgui (folgui@bigfoot.com), RedDwarf, Hades666, KaBeCi, PolloPolea, Moises Déniz.||Thanks to Culturalia's webmaster for his help and for providing more direct access to his database.||
ImportLengthIMDB=1|0|0=Imports Length from Culturalia (no info)|1=Imports Length from IMDB
ImportRatingIMDB=1|0|0=Imports Rating from Culturalia (no info)|1=Imports Rating from IMDB
BatchMode=0|0|0=Normal working mode, prompts user when needed|1=Does not display any window, takes the first movie found
program Culturalia_IMDB;
  StringUtils1;
  BaseURLCulturalia = 'http://www.culturalianet.com/bus/catalogo.php';
  MovieName, strTemp, donde: string;
  Articles: array of string;
  Index: integer;
procedure AnalyzePageIMDB(Address: string);
  PageText: string;
  Value: string;
  PageText := GetPage(Address);
  if pos('<title>IMDb', PageText) = 0 then
    AnalyzeMoviePageIMDB(PageText)
        ShowMessage('No se ha encontrado ninguna coincidencia');
      Exit;
        Value := TextBefore(PageText, '<ol>', '<b>');
        if Value <> '' then
          HTMLRemoveTags(Value);
          HTMLDecode(Value);
          PickTreeAdd(Value, '');
        Value := TextBetween(PageText, '<ol>', '</ol>');
        PageText := RemainingText;
      until not AddMovieTitles(Value);
      Value := TextBefore(PageText, '"><b>more titles</b></a>', '<a href="');
      if Value <> '' then
        PickTreeMoreLink('http://former.imdb.com' + Value);
        AnalyzePageIMDB(Address);
      Value := TextBetween(TextBetween(PageText, '<ol>', '</ol>'), '<li>', '</li>');
      if Value <> '' then
        AnalyzePageIMDB(TextBetween(Value, '<a href="', '">'));
procedure AnalyzeMoviePageIMDB(PageText: string);
  Value: string;
  // Rating
  if (GetOption('ImportRatingIMDB') = 1) then
   Value := TextBetween(PageText, '/rating-stars/', '/rating-vote/');
   SetField(fieldRating, TextBetween(Value, '<b>', '/'));
  // Length
  if (GetOption('ImportLengthIMDB') = 1) then
    Value := TextBetween(PageText, '<b class="ch">Runtime:</b>' + #13#10, ' ');
    if Value <> '' then
      if Pos(':', Value) > 0 then
        SetField(fieldLength, TextAfter(Value, ':'))
        SetField(fieldLength, Value);
  Value: string;
  Address: string;
  Result := False;
  Value := TextBetween(List, '<li>', '</li>');
  List := RemainingText;
  while Value <> '' do
    Address := TextBetween(Value, '<a href="', '">');
    HTMLDecode(Value);
    PickTreeAdd(Value, Address);
    Result := True;
function TransformTitle(Title: string): string;
  BeginPos, EndPos: Integer;
  Value: string;
  Words: array of string;
  Replace,Original: string;
  Index, CommaCount: Integer;
Begin
  // Original Title
  Result:=Title;
  Setarraylength(Words,11);
  Words[0]:=' In ';
  Words[1]:=' On ';
  Words[2]:=' Of ';
  Words[3]:=' As ';
  Words[4]:=' The ';
  Words[5]:=' At ';
  Words[6]:=' And A ';
  Words[7]:=' And ';
  Words[8]:=' An ';
  Words[9]:=' To ';
  Words[10]:=' For ';
  SetArrayLength(Articles,35);
  Articles[0]:=' The';
  Articles[1]:=' a';
  Articles[2]:=' An';
  Articles[3]:=' Le';
  Articles[4]:=' L''';
  Articles[5]:=' Les';
  Articles[6]:=' Der';
  Articles[7]:=' Das';
  Articles[8]:=' Die';
  Articles[9]:=' Des';
  Articles[10]:=' Dem';
  Articles[11]:=' Den';
  Articles[12]:=' Ein';
  Articles[13]:=' Eine';
  Articles[14]:=' Einen';
  Articles[15]:=' Einer';
  Articles[16]:=' Eines';
  Articles[17]:=' Einem';
  Articles[18]:=' Il';
  Articles[19]:=' Lo';
  Articles[20]:=' La';
  Articles[21]:=' I';
  Articles[22]:=' Gli';
  Articles[23]:=' Le';
  Articles[24]:=' Uno';
  Articles[25]:=' Una';
  Articles[26]:=' Un''';
  Articles[27]:=' O';
  Articles[28]:=' Os';
  Articles[29]:=' As';
  Articles[30]:=' El';
  Articles[31]:=' Los';
  Articles[32]:=' Las';
  Articles[33]:=' Unos';
  Articles[34]:=' Unas';
  // Count the Comma in The Title
  CommaCount := 0;
  EndPos := 0;
  Value := Title;
     BeginPos := Pos(',', Value);
     if BeginPos > 0 then
       Delete(Value, 1, BeginPos);
       CommaCount := CommaCount + 1;
       EndPos := EndPos + BeginPos;
  until( Pos(',',Value) = 0);
  // Compare the Article to a list of known ones
  for Index := 0 to 34 do
    if Pos(Articles[Index], Value) <> 0 then
       CommaCount := 1;
       BeginPos := EndPos;
  if (BeginPos > 0) and (CommaCount = 1) then
    Value := Copy(Title, BeginPos + 1, Length(Title));
    Value := Trim(Value);
    Result := Value + ' ' + Copy(Title, 1, BeginPos - 1);
  BeginPos := Pos(': ', Result);
    Result := StringReplace(Result, ': ', ' - ');
  Result := AnsiMixedCase(Result, ' ');
  for Index := 0 to 10 do
    if Pos(Words[Index],Result) <> 0 then
      Original := Words[Index];
      Replace := AnsiLowerCase(Original);
      Result := StringReplace(Result, Original, Replace);
  Result := StringReplace(Result, ' - the ', ' - The ');
  Result := Trim(Result);
procedure AnalyzePageCulturalia(Address: string);
  Page, TempTit: TStringList;
  Code, Title, TitleOrig, Year: string;
  TitleFound: Boolean;
  TempTit := TStringList.Create;
  if Pos('No se ha encontrado ningún artículo por título', Page.Text) = 0 then
       LineNr := 1;
       PickTreeAdd('Resultados más probables de la búsqueda:', '');
         Code := TextAfter(Page.GetString(LineNr), 'Codigo = ');
         Title := TextAfter(Page.GetString(LineNr+1), 'Titulo = ');
         TitleOrig := TextAfter(Page.GetString(LineNr+2), 'Titulo original = ');
         Year := TextAfter(Page.GetString(LineNr+3), 'Año = ');
         PickTreeAdd(Title + ' (' + TitleOrig + '), ' + Year, BaseURLCulturalia + '?catalogo=1&codigo=' + Code);
         LineNr := LineNr + 5;
         AnalyzeMoviePageCulturalia(Address);
      LineNr := 1;
      TitleFound := True;
      Address := (BaseURLCulturalia + '?catalogo=1&codigo=' + Code);
      if TitleFound then
  if (GetOption('BatchMode') = 0) then
procedure AnalyzeMoviePageCulturalia(Address: string);
  Comments: string;
  strTitle: string;
  strSinopsis: string;
  strTemp: string;
  strTitle := TextAfter(Page.GetString(1), 'Titulo = ');
  if copy(strTitle, Length(strTitle), Length(strTitle)) = '.' then
    strTemp := Copy(strTitle, 1, Length(strTitle) -1);
    strTemp := strTitle;
  SetField(fieldTranslatedTitle, TransformTitle(strTemp));
  strTemp := TextAfter(Page.GetString(2), 'Titulo original = ');
  SetField(fieldOriginalTitle, TransformTitle(strTemp));
  SetField(fieldYear, TextAfter(Page.GetString(3), 'Año = '));
  SetField(fieldCategory, TextAfter(Page.GetString(4), 'Genero = '));
  SetField(fieldCountry, TextAfter(Page.GetString(5), 'Nacion = '));
  SetField(fieldDirector, TextAfter(Page.GetString(6), 'Director = '));
  SetField(fieldActors, TextAfter(Page.GetString(7), 'Actores = '));
  SetField(fieldProducer, TextAfter(Page.GetString(8), 'Productor = '));
  Comments := 'Guión: ' + TextAfter(Page.GetString(9), 'Guion = ');
  Comments := Comments + #13#10 + 'Fotografía: ' + TextAfter(Page.GetString(10), 'Fotografia = ');
  Comments := Comments + #13#10 + 'Música: ' + TextAfter(Page.GetString(11), 'Musica = ');
  LineNr := FindLine('Sinopsis = ', Page, 0);
  strSinopsis := TextAfter(Line, 'Sinopsis = ');
  LineNr := LineNr + 1;
  while pos('URL = ', Line) = 0 do
    strSinopsis := strSinopsis + #13#10 + Line;
  HTMLRemoveTags(strSinopsis);
  SetField(fieldDescription, StringReplace(StringReplace(strSinopsis, '“', '"'), '”', '"'));
  LineNr := FindLine('URL = ', Page, 0);
  if LineNr <> -1 then
    SetField(fieldURL, TextAfter(Page.GetString(LineNr), 'URL = '));
    GetPicture(TextAfter(Page.GetString(LineNr), 'Imagen = '));
  SetArrayLength(Articles,11);
  Articles[0]:='Lo ';
  Articles[1]:='La ';
  Articles[2]:='Le ';
  Articles[3]:='Uno ';
  Articles[4]:='Una ';
  Articles[5]:='Un ';
  Articles[6]:='El ';
  Articles[7]:='Los ';
  Articles[8]:='Las ';
  Articles[9]:='Unos ';
  Articles[10]:='Unas ';
if CheckVersion(3,5,0) then
    MovieName := '';
     donde := '&donde=1';
       MovieName := GetField (fieldOriginalTitle);
       donde := '&donde=2';
       Input('Importar de Culturalia', 'Introduzca el Titulo de la Pelicula:', MovieName);
    If MovieName <> '' then
        strTemp := MovieName;
        if Copy(strTemp, Length(strTemp), Length(strTemp)) = '.' then
          MovieName := Copy(strTemp, 1, Length(strTemp) -1);
        AnalyzePageCulturalia(BaseURLCulturalia + '?catalogo=1&texto=' + UrlEncode(MovieName) + donde);
        if (GetOption('ImportRatingIMDB')=1) or (GetOption('ImportLengthIMDB')=1) then
          AnalyzePageIMDB('http://former.imdb.com/find?tt=1;q='+UrlEncode(GetField(fieldOriginalTitle)));
     ShowMessage('Este script requiere una versión más reciente de Ant Movie Catalog (al menos la versión 3.5.0)');
rocanrol
Post by rocanrol »
Muchas Gracias folgui
Ahora parece que hay un problema con la importación de la sinopsis desde culturalia.
Saludos
Thxs Folgui
By now, it seems like there is some trubble during the importation of the plot from Culturalia
Greetings
folgui
Post by folgui »
rocanrol wrote:Ahora parece que hay un problema con la importación de la sinopsis desde culturalia.
¡Hola!
ES: ¿Puedes ponerme un ejemplo de película donde no funcione? Yo lo llevo usando desde la modificación y no he tenido ningún problema.
EN: Can you tell me with what film it doesn't work? I have been using it since modification y haven't got any problems.
Saludos, folgui.
rocanrol
Post by rocanrol »
Para cualquier película aparece el siguiente mensaje:
In any film this message appears:
Error de Script en "CULTURALIA_IMDB": unknown identifier: FINDLINE en la línea 295
Check that you have the file Stringutils1.pas up-to-date (you can get it from www.antp.be/temp/scripts)
But that strange since it is included with the program since long time.
rocanrol
Post by rocanrol »
Thanks folgui and antp, overwriting the old *.pas files worked for me perfectly
Gracias a folgui y antp, sobreescribiendo los archivos antiguos *.pas se solucionó el problema
lestatou
Post by lestatou »
Hola.
He actualizado el codigo del script culturalia para que importe la duracion y la valoracion pero no lo hace. 1º me aparece la lista de peliculas, escojo la correcta y me lo importa todo menos eso. 2º me sale un pop up de "no movie found".
Ke puede ser? gracias.
Hi
I've updated the script with new code, but it doesn't imports length and rating. First appears the list of movies to choose and imports almost all the info, buet at the end of importation process appears a pop with "no movie found".
What happens?
Thanks a lot.
