Sort->MediaLabel
Scriabin
Sort->MediaLabel
Post by Scriabin »
Hi all first, this is my debut in this forum.
Let's see my problem: it happens when I try to sort my database by MediaLabel variable.
here's the screenshot:
The numbers are not ordered as you can see: 10 must be after 9 and not just after 1, the same for 100...it should be after 99 but it's just after 10.
If I try to export the database I obtain the same type of sorting.
I need it to be 1-2-3.....9-10-11.....99-100-101.... and not 1-10-100-101...and so on.
what's wrong?
Nothing's wrong ;)
I think it is because MediaLabel is no 'integer' but some kind of 'string' variable, and then it is the normal behaviour. In MediaType field you cannot use numbers only, but all kind of letters. Sorting will start with the first letter of the word (or integer), then read the second one, third one - and so on.
You should add some leading '0' if you want to get a proper listing.
001
002
010
011
But maybe I'm wrong and there is a better solution ? ;)
Scriabin
Post by Scriabin »
it's a hard hard work...I have to change my over three hundred labels in something like 0001-0002...? :cry:
I hope there's a better solution...
This can be done easily using a script, I think that I posted that somewhere on the forum some time ago.
I do not have time right now, I'll post it within 1h if you haven't found it until then.
Scriabin
Post by Scriabin »
I've tried a lot of searches in this forum, maybe the wrong words...
Thanks in advance for your help
:D
OK so here is it:
program NewScript;
  s: string;
  s := GetField(fieldMedia);
  if s <> '' then
    while Length(s) < 4 do
      s := '0' + s;
    SetField(fieldMedia, s);
Go to tools -> scripting, or press F6.
Be sure that in "script limitations" you have checked "all" (or "selected" if you want to modify only the selected movies).
In the "editor" tab click the "new" icon and replace the script template by the one above.
The click run and it should be done ;)
(you can reply "no" when the program asks if you want to save the script, except if you want to reuse it later)
Scriabin
Post by Scriabin »
Wonderful, it works!!!!!!!!!!!!! :clapping:
