Cannot find Report Designer
StuLux
Post by StuLux »
This database looks just like what I need but I would like to design my own print output. However when I click on designer I get the message "Cannot Find Report Designer. AMCReport.exe must be in the same folder than Ant Movie Catalog". However despite a search of my PC I cannot find any file called AMCReport.exe - is this supplied as a separate download or is there anyway I can get hold of the designer part of the program.
It is included with the program. Did you use the installer? What version do you have?
StuLux
Post by StuLux »
Yes I believe I did use the installer. I have version 3.5.0.2, I only installed it yesterday 26th Feb so presumably it is the latest version. Can the file be obtained separately or should I try a complete reinstall?
StuLux
Post by StuLux »
I've just managed to get the following "error" message when I click on the versions button in the "about" window if this helps?
Information
MovieCatalog.exe : version 3.5.0.2 (29/05/2005 12:51:40)
AMCExchange.dll - Unable to read file information
AMCReport.exe - Unable to read file information
(press Ctrl+C if you want to copy these information to clipboard)
OK
Thermal Ions
Post by Thermal Ions »
This is what I get - so a re-download and reinstall might be the way to go.
Information
MovieCatalog.exe : version 3.5.0.2 (29/05/2005 11:51:40 AM)
AMCExchange.dll : version 1.0.1.6 (26/06/2004 11:39:22 PM)
AMCReport.exe : version 1.0.2.2 (15/01/2005 4:13:56 PM)
MediaInfo.dll : version 0.6.0.0 (18/05/2005 10:45:58 PM)
Cheers........Thermal
StuLux
Post by StuLux »
Problem solved now (thanks) following a reinstall. I think maybe I did not use the installer first time around and this was the cause of the problem.
