catagorie listing
Albetra Boy
catagorie listing
Post by Albetra Boy »
Not sure if this is the right spot but I took a screen pic so that you would see what I was talking about.
The cagagories in the chart repeat its self.
For "Horror" for example it is clearly visible that some have a space in front of the name, and others don't.
I guess that for the others it is a similar problem.
Albetra Boy
antp wrote:For "Horror" for example it is clearly visible that some have a space in front of the name, and others don't.
ugh i though that might be it thanks
