Request of small modyfication
RDI
Post by RDI »
Hi
After using your program for a long time a had two ideas that may improve it:
1. Is it possible to do a modification of 'Media file information' and add option 'Import folder name as title' - will be very helpful - especialy for me :)
2. Adding an option to make fields read only, after update nessesary information. I use "media type' field to store dvdr numbers and very often happends after viewing my catalog by friends or wife everything is in great mess :)
I looked on forum but not find any helpful solutin.
1. it could be added
2. I think that it is on my to-do list
the only problem is that it may take time before such options appear, as I do not work often on the program :/
