Problem with loading and saving
almarher
Post by almarher »
Hello, i have a catalog with 1700 films and program needs 2 minutes for loading and saving file. What can i do????
Thank you very much
Well, I guess that the catalog file is quite huge then, due to large pictures.
Only solution currently is to use external pictures. You can save the catalog to XML (using file -> Save As), this will put the pictures outside of the catalog. As they go in the same folder, it is better to have the catalog in a folder dedicated to it, so files do not get mixed with other things.
You can save back to AMC format later, or keep the XML file. In both cases you can specify in the preferences that by default future pictures will have to be stored as external files.
