default values disappeared, please help
Jev
Post by Jev »
Hello
I am using the latest version of Ant Movie Catalog 3.4.1 from Dec 23, on Windows XP pro SP1
Suddenly today all the default values from drop downs have disappeared, I can;t select country, movie format, codec, and so on. The existing XML database looks ok but for new entries it''s a big problem
Any help woould be greatly appricated
Sincerely
jev
You can edit that in Tools -> Preferences -> Drop down lists.
If you want to get original values back you can do that by overwriting your preferences files (moviecatalog.xml) with the default one, that you can get there : ftp://ftp2.antp.be/antp/software/amc_defoptions.zip
Jev
Post by Jev »
Thank you
I reinstalled and it helped
