html-eport= picture and sorted problems
hallfi
Post by hallfi »
I searched for this problem but i didn`t find anything. :)
Every Time I put a new film in the catalog a problem occurs- the html-export went wrong.
Every new film I entered into the system is placed on the right place with his name... but he shows a wrong item number. f.e. I entered the film abyss and it shows the number 96. tried to solve this problem with the sorted-function but it didn't work.
furthermore the film picture isn't the right one. the picture displayed belongs to the film above or under the new movie
that means he changed all the film pictures from inserting the new film.
I`m working with a modified html-template.
So…anyone have an idea?
Thanks a lot.
If you change the numbers (e.g. using the renumber tool) it is normal that the number do not match anymore, you have to delete pictures first, or to disable the "Only if does not exist" option for pictures in export window.
If several movies have the same number, there is currently a bug. The only workaround for that case is to use title rather than number for the images names (this can be chosen in the preferences window).
