prefs.xml
rs1975
prefs.xml
Post by rs1975 »
every time when i close ant movie catalog program creates this file prefs.xml in my desktop. what must i change so this file wont be craeted in my desktop?
That's strange, I wonder why it puts it there :??: It is supposed to be in the program's folder.
Is there anything special in the shortcut that you use to launch the program? Or do you use the shortcut icon created by the installation?
