Find duplicates
Ork
Find duplicates
Post by Ork »
Here is a script that find all duplicates.
It writes the results in c:\duplicates.txt along with the numbers of each occurence of the duplicate title.
To change the file, simply change the value at the end of the code (line 98).
//SCRIPTING
//Find duplicates in a list
 *  Script to find duplicates in the list of       *
 *  selected movies.                               *
 *  It doesn't see empty fields.                   *
 * (c) 2003 Louis Francisco ork@everydayangels.net *
 *  For use with Ant Movie Catalog 3.4.1           *
program FindDuplicates;
  NMAX=260; //Set to the last number in the list
  Titles:TStringList;
  Numbers:TStringList;
  Duplicates:TStringList;
  CurrentTitle:string;
  CurrentNumber:string;
function FindTitle(title:string;list:TStringList):integer;
  i:integer;
  result:=-1;
  for i:=0 to list.Count-1 do
    if list.GetString(i)=title then
      result:=i;
      break;
procedure FindDuplicates();
  numTitle,numDup:integer;
  numTitle:=FindTitle(CurrentTitle,Titles);
  if numTitle<>-1 then
    numDup:=FindTitle(CurrentTitle,Duplicates);
    if numDup=-1 then
      Duplicates.Text:=Duplicates.Text+
        CurrentTitle+' ('+Numbers.GetString(numTitle)
        +', '+CurrentNumber;
      Duplicates.SetString(numDup,
        Duplicates.GetString(numDup)+', '+CurrentNumber);
  Titles.Text:=Titles.Text+CurrentTitle;
  Numbers.Text:=Numbers.Text+CurrentNumber;
procedure SaveToFile(fileName:string);
  i:integer;
  for i:=0 to Duplicates.Count-1 do
    Duplicates.SetString(i,Duplicates.GetString(i)+')');
  Duplicates.SaveToFile(fileName);
  if CheckVersion(3,4,1) then
    if Titles=nil then
      Titles:=TStringList.Create;
      Numbers:=TStringList.Create;
      Duplicates:=TStringList.Create;
    CurrentTitle:=GetField(fieldOriginalTitle);
    CurrentNumber:=GetField(fieldNumber);
    // If title is empty, it generates bugs while looking to the
    // number of a duplicate movie.
    if CurrentTitle<>'' then FindDuplicates;
    if StrToInt(CurrentNumber,0)=NMAX then
      SaveToFile('c:\duplicates.txt');
      Titles.Free;
      Numbers.Free;
      Duplicates.Free;
    ShowMessage('This script requires a newer version of Ant Movie Catalog (at least the version 3.4.1)');
Thanks ;)
furetto
Post by furetto »
is it possible to have a newer version of this script, so it can be used with version 3.5 ?
I tried to use it with the new version of AMC, but it doesn't work :cry:
toff
Post by toff »
9 years after, I'm seconding that :)
The one included in AMC does not work?
(accessible via Tools->Scripting)
kveda
Post by kveda »
I have been looking in scripting and didn´t find the option.
How can i find duplicates.
Regards
In Tools->Scripting you do not have "Find Duplicates" that appears in the list?
It is included with AMC's standard install but if you don't have the script you can find it on http://update.antp.be/amc/scripts/archive/
