Import from SQL to AMC
vipyammer
Post by vipyammer »
Hoi,
Jus lost all my created local AMC sources...
Before I all exported to SQL and imported into my SQL DB host. Al pictures are also there...
Is there a way to import the SQL DB into AMC again?
Geez,
Vipyammer
Not directly.
But if you know a little PHP you could generate a CSV file that you can import in AMC.
Or maybe somebody already wrote that?
vipyammer
Working (Topic can be closed)
Post by vipyammer »
Just exported the SQL DB to an CSV file. Imported into AMC and all fine now.
Thanks...
Vipyammer
mjs7231
Post by mjs7231 »
For anyone else wanting to do this. I believe both applications below can export a MySQL database to CSV.
SQLYog: http://www.webyog.com/en/
PHPmyAdmin: http://www.phpmyadmin.net/home_page/index.php
