Export "some" movies from a list into a new list ?
v2.01
Post by v2.01 »
My problem: I would like to export "some" movies from a list into a new list. amc to amc How can I do that?
ABNormal
Post by ABNormal »
export them in csv
then import them into new list from that csv file
i think it's the right way
ABN
As I replied by e-mail (I guess that you didn't receive the reply ?):
You have to do it in the other way: import the few movies into another list (a new one or an existing one) using File -> Import menu.
v2.01
Post by v2.01 »
Thanks. This works.
