Ant Movie Catalog on My Blog...
Lul2x
Post by Lul2x »
I found AMG so great that I just had to spread the word, check it out. I'd like to add audio to the video once I get a mic :hum:
http://pbriscoe.com/2007/01/07/how-to-c ... ur-movies/
mjs7231
Re: Ant Movie Catalog on My Blog...
Post by mjs7231 »
Lul2x wrote:I found AMG so great that I just had to spread the word, check it out. I'd like to add audio to the video once I get a mic :hum:
Very cool.. :)
Nice :)
Lul2x
Post by Lul2x »
Thanks, glad you guys like it. I figure, you both have put so much work into your projects and they are so great, that I had to give you credit somehow. :)
