The "Number" column width is too small
aldi
Post by aldi »
The "Number" column width is too small.
Numbers above 100000 cant see. Resizeble is unavailable too.
Here is screeshot:
It is because in previous versions numbers were limited to a lower number. I forgot to make the column sizeable when I removed this limit...
