Ant Movie Catalog crashes after a while.
w00t
Post by w00t »
After i try to open the "drager" tab, the program hangs. I have tried it several times, but it hangs as soon as i touch the "drager" field. Also, the problem continues on explorer.exe when i kill the moviecatalog.exe process.
It happens over and over again. At first i thought it could have someting to do with Norton Internet Security. But even with NIS turned off, the problem persists.
Is this a known error, or am i doing someting wrong?
Some information i get from windows:
szAppName : moviecatalog.exe szAppVer : 3.5.0.2 szModName : hungapp
szModVer : 0.0.0.0 offset : 00000000
http://www.dwaaz.com/appcompat.txt
http://www.dwaaz.com/moviecatalog.exe.mdmp
wfr,
Martin
What's the "drager" tab?
If you have a nVidia-based video card, try to update the driver and/or disable the "nView Desktop" functionnality, as it is known to cause such problems with AMC (and I haven't found why yet).
Timo
Crash only with latest version?
Post by Timo »
hi i have the same problem and i thought with the previous version that the program runned smpothly... Even if i disable the nvdia manager it crashes after a while
I find it very annoying and want to know where i can get previous versions not with ftp because i don't know how to download it with an ftp site???
For the rest a very nice and handy program ...keep up the good work
It is the "nView Desktop" feature that you have to completely disable (not just uncheck some options)
There is a link to old versions on the FTP: ftp://ftp2.antp.be/antp/software/old/
These can be downloaded like from a normal HTTP server.
If in your browser it is displayed like a folder and not like a server list, you should be able to copy/paste the file to somewhere else, or just open it from that location.
uh_Andy
Post by uh_Andy »
Great info - solved for me. In my case I was able to go into control panel, choose 'nvidea nview desktop manager', and click the disable button.
berkana83
I have had the same problem
Post by berkana83 »
I have had the same problem!!!! Thanks for the replies, now my Ant Movie Catalog works as in the begining!!! I love this program!!!!! :D
