[REQ] Set 'Execution Options' from within a script ?
Good morning ^^
I've started writing another script for AMC and it would be nice if I could set the 'Show results window' (found in 'Execution Options') to off from within the script.
I want to hide the result window, because in this script it is not needed at all.
Is there a possibility or an undocumented variable for this ?
Would be really important.. as this script should even work for the most stupid AMC users alive ;)
It is not possible currently.
By default in scripting mode (Shift+F6) this result window is not displayed, as the purpose is to do batch-changes to lots of movies rather than importing movie info for one or few movies.
That's also why the script can be shown in this mode only, if its purpose is not importing info from internet. For that there is the "Get info from web" attribute in script properties.
:/ Thanks !
