About several films on disk
fetis
Post by fetis »
First of all, thanks for GREAT programm!
I have troubles when some films recorded on a one disk. I add it into catalog, but I can't join it in one disk. Yes, I know about Media Label, but I use it for other things already.
I think this would be new feature, call it Disks. You create new disk and add films to it. Probably the field Disks should be changed. It should refere on Disk entry, where the media, amount of disks and other things are stored.
What you say?
I have to so some heavy change to really handle "media" separately from the movie info. So it will not arrive quickly.
I do not know what you could do. What do you do with the Media Label field?
fetis
Post by fetis »
Media Label field helps me separate disk for categories: movie, music, soft etc.
Well, you could use one of the other fields for this then? I cannot suggest anything else, as you will have to find a way to use the program as it is currently. These changes will not be made so quickly due to the huge amount of things that are waiting to be added :/
fetis
Post by fetis »
I'm ready to wait :) Just put this feature in your tracker
