[REQ] How to end/stop a script immediatly ?
Hi, I'm writing a new script for a german website but now I need some helping hand.
Is there any command to end a script immediatly or some kind of 'GOTO end.' ?
I need this function because I want to end a script with a message (ShowMessage), when two 'IF GetOption' conditions are fulfilled.
Thanks.
You can exit from current function/procedure with "Exit" command.
To stop the script there is an "Error" function but that does not stop it very properly (I think that it shows a message to the user).
Thanks, 'Exit' works fine.
