Suggestion for Statistics feature
rringeisen
Post by rringeisen »
I would like it if, while viewing statistics, I could choose whether or not to include a field on the pie/chart.
For example; show all titles that are not in english language, and the proportion of them.
I would like this feature on, Additions, Countries, etc
When you say "not in English language", you mean where the "language" field is set to something else than English?
You could have that by two ways:
- either group by the field, and with that you can easily select groups of movies,
- or use the search and the "display results" option
then in the stats you can ask to only include in stats the movies that are selected or those that are visible (i.e. in search results)
rringeisen
Yeah, the search funtion could work. Such as searching for all movies added in 2005, selecting them, and having them be part of the statistics pie chart/graph.
Though, what I was asking about, was including an "include/exclude" option on the statistics.
If I'm looking at the graph of movie years, and want to exclude a certain graph from the display. Or the pie chart of languages, and want to exlude a particular one from the chart.
That could be easily added, I think. I'll add it on my (huge) 'to-do' list
rringeisen
Thank you!
