a problem
SLover
a problem
Post by SLover »
when i want to print the cover, the catalog doesn't display correctly the russian characters. It doesn't use a russian encoding.
Can u help me ? What is the problem ? What should i do in this case ?
This may be due to the template that you use. Maybe it has a western-european font defined. You have to open it in the report designer and select another font for each text bloc (e.g. Arial CYR)
SLover
Post by SLover »
antp wrote:This may be due to the template that you use. Maybe it has a western-european font defined. You have to open it in the report designer and select another font for each text bloc (e.g. Arial CYR)
thanks, this helped me :)
thanks a lot
