no movie found
szupien
no movie found
I have the problem with script I think so when I try to take information everything going good, but after when I select the movie which I want, program alert: no movie found. please help.[/i]
With which script? It is probably a problem related to the script...
Check if a newer version of the script is on www.antp.be/temp/scripts/
If not then it may mean that the script still has to be updated.
