Edit field of multiple selected movies
EricAllenStiles
Post by EricAllenStiles »
This program is great. I would like to add a sugestion.
I think it would be great if you could edit a field of multiple movies. For example: Say your in the normal display, not the grid mode. On the left you select 5 movies. Then you go over to you Media Type field and type in DVD. The Media type would then be changed to DVD for all 5 movies that you had selected.
I know you can do this with a script but for the novice computer person, typing directly in the field would be more user friendly.
Anyway, nice program.
Eric
With the "update fields" script it should be quite easy.
Anyway I will do a script easier to use than this one.
You just have to run the script, select the field to change in a list, then type the value.
EricAllenStiles
That's sound good.
The script that you do have does work, but I think there are some spelling errors with it, for example I think one points to a different field than what it says, in the english text.
