How to show only replaced filenames in preview column ?
pstein
Post by pstein »
Assume I want to perform a replace operation.
A given search string is only found in some but not all of the loaded files.
Hence only a subset of filenames are changed.
Unfortunately in the preview column ALL file(names) are listed.
Is there way only to list new filenames to which a replace operation is applicable and remain the other file rows blank ?
If not: can such an option be included in future versions ?
I guess that it is currently not possible if it is not done, but it is a good idea for the next version, I will add that to my to-do list ;)
